You are here: PSPad forum > English discussion forum > Macro buttons
Macro buttons
#1 Macro buttons
Posted by: maki | Date: 2020-02-04 10:17 | IP: IP Logged
How to write Macro, and put a thousand, hundreds of buttons for specific search by Regex?
#2 Re: Macro buttons
Posted by: pspad | Date: 2020-02-04 11:09 | IP: IP Logged
I'm sorry, I don't understand the language of your tribe
#3 Re: Macro buttons
Posted by: maki | Date: 2020-02-04 11:18 | IP: IP Logged
I want to write a macro for regular expressions (or record a macro while doing the search).
#4 Re: Macro buttons
Posted by: pspad | Date: 2020-02-04 11:29 | IP: IP Logged
Use Find/replace profiles. If you disable inserting text under cursor into search fiels, you can simple run it with Ctrl+H, Enter
Use User convertors - you can use regular expressions there and you can run last used convertor with shortcut.
Write script, you can du anything there.
