You are here: PSPad forum > English discussion forum > Configuration problem on some OS Windows 7 Ultimate X64
Goto Page: 1 2 Next
#1 Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-03 17:52 | IP: IP Logged
AppData\Roaming\PSpad\Recent.INI
PSPad application error (64-bit only).
It seems to me that the tabs disappear or other data loss.
Caused by:
Line:
[Recent] Items
forum.pspad.com
Edited 3 time(s). Last edit at 2020-02-03 18:00 by maki.
#2 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-03 18:02 | IP: IP Logged
Last Open Tabs that have been incorrectly initiated cause PSPad crashes, of course, for some reason, the Tabs disappear when some internal PSPad error occurs. So data loss is inevitable.
#3 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: pspad | Date: 2020-02-03 18:30 | IP: IP Logged
What data lost? Last open tabs or recent? Nothing of it are "important data"
#4 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-03 20:29 | IP: IP Logged
For me, restoring data when a text file could not be saved due to hang or error is very important.
Some are working on a long-term project. I would like it to be able to automatically save my workspace, including all open files (tabs) and even an Undo history!
#5 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: pspad | Date: 2020-02-04 04:18 | IP: IP Logged
Save more often, not once a day and make backups. Your data lost won't be so big.
#6 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-04 11:08 | IP: IP Logged
I can suggest this configuration in future versions
Backup -> Auto Save [XX] Minutes
Rename if the Same File Name Exists
I think there was once a very simple text editor that saved changes in real time! In another file.
The file at the end of the extension had ~
Edited 1 time(s). Last edit at 2020-02-04 11:11 by maki.
#7 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: pspad | Date: 2020-02-04 11:10 | IP: IP Logged
Autosave is implemented.
PSPad backups file into same location as original file or into backup folder with different name. For more information see the included help file.
#8 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-04 11:15 | IP: IP Logged
PSPad still generates dump files all the time.
I also have data loss all the time.
PSPad is having trouble accessing the system folder for saving configuration *.INI!
#9 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: pspad | Date: 2020-02-04 11:25 | IP: IP Logged
You are asking for autosave.
I answered that autosave is implemented with backups.
Your reaction? Useless message about dumps. If PSpad crashes for you, use another editor. I will have more time for development instead of answer your endless question and requests,
Before you will write another question, try to investigate, if subject of your question isn't already implemented or answered. Start use the help file.
From now I will react only to your questions with complete problem description, eventually with useable examples.
If question stays without answer, it means that is necessary to add another information.
#10 Re: Configuration problem on some OS Windows 7 Ultimate X64
Posted by: maki | Date: 2020-02-04 11:31 | IP: IP Logged
This error occurs when I have UAC: High enabled on Windows 7
Probably caused by:
An error occurred while applying security settings in AppData\Roaming\PSPad\Recent.INI. Users is not a valid user or group.
Edited 1 time(s). Last edit at 2020-02-04 11:33 by maki.
Goto Page: 1 2 Next
