You are here: PSPad forum > English discussion forum > PSPad Syntax Error "Date Regex"
Posted by: pspad | Date: 2020-01-29 18:37 | IP: IP Logged
Can you show me your regular expression?
Posted by: maki | Date: 2020-01-29 19:00 | IP: IP Logged
PSPad not support .NET Regular Expressions?
What engine does it use?
Posted by: pspad | Date: 2020-01-29 19:27 | IP: IP Logged
PSPad uses Perl syntax.
But it's no problem to implement another library what will support your expressions.
Tested for Search/Replace and it works, include date validation:
^(?:(?:31(\/|-|\.)(?:0?[13578]|1[02]))\1|(?:(?:29|30)(\/|-|\.)(?:0?[13-9]|1[0-2])\2))(?:(?:1[6-9]|[2-9]\d)?\d{2})$|^(?:29(\/|-|\.)0?2\3(?:(?:(?:1[6-9]|[2-9]\d)?(?:0[48]|[2468][048]|[13579][26])|(?:(?:16|[2468][048]|[3579][26])00))))$|^(?:0?[1-9]|1\d|2[0-8])(\/|-|\.)(?:(?:0?[1-9])|(?:1[0-2]))\4(?:(?:1[6-9]|[2-9]\d)?\d{2})$
Edited 2 time(s). Last edit at 2020-01-29 21:22 by pspad.
Posted by: maki | Date: 2020-01-29 22:18 | IP: IP Logged
Your regex not work PSPad.
can start learning...
But here's the date in a different format:
XXXX-XX-XXX
www.oreilly.com
Edited 1 time(s). Last edit at 2020-01-29 22:21 by maki.
Posted by: pspad | Date: 2020-01-29 22:27 | IP: IP Logged
There is big problem, cause you don't read.
Quote:But it's no problem to implement another library what will support your expressions.
It means I implemented new regular expression library (PCRE instead of PERL) and this library supports regular expression like yours.
You must wait, cause I need to make modification in whole PSPad.
Posted by: maki | Date: 2020-01-30 11:20 | IP: IP Logged
You can add new functions, or allows you to quickly select operations - 1 click, without having to enter all the time regex.
HTML Anchor tag
<a\s+(?:(?:\w+\s*=\s*)(?:\w+|"[^"]*"|'[^']*'))*?\s*href\s*=\s*(?<url>\w+|"[^"]*"|'[^']*')(?:(?:\s+\w+\s*=\s*)(?:\w+|"[^"]*"|'[^']*'))*?>.+?</a>
Match:
<a href="/feed?section=search&q=%23%D0%91%D0%9F_%D0%A3%D0%BA%D1%80%D0%B0%D0%B8%D0%BD%D0%B0">#БП_Украина</a>
Edited 1 time(s). Last edit at 2020-01-30 11:21 by maki.
Posted by: pspad | Date: 2020-01-30 11:29 | IP: IP Logged
maki:You can add new functions, or allows you to quickly select operations - 1 click, without having to enter all the time regex.
I am afraid I don't understand
Posted by: maki | Date: 2020-01-30 11:35 | IP: IP Logged
In the Find section, optional user search selection
Posted by: maki | Date: 2020-01-30 11:43 | IP: IP Logged
I have sample regular expressions ready and quickly want to choose a search?
It makes no sense to copy from thousands of ready-made regular expressions for everyone. It has to be improved somehow!
Posted by: maki | Date: 2020-01-30 11:51 | IP: IP Logged
Example:
Find -> Ready-Made Regex -> URL Image
(http\:\/\/[a-zA-Z0-9\-\.]+\.[a-zA-Z]{2,3}(?:\/\S*)?(?:[a-zA-Z0-9_])+\.(?:jpg|jpeg|gif|png))
akademiaszczescia.com/wp-content/uploads/2017/05/diagram-1010x1024.png
