You are here: PSPad forum > English discussion forum > Failure error meesage
Goto Page: Previous1 2
#11 Re: Failure error meesage
Posted by: maki | Date: 2020-01-10 11:28 | IP: IP Logged
Listen, it's formal, but don't overdo it. I wrote culturally that I don't use the 32-bit version, so how do I know how the 32-bit version works?
Provide a link to portable 32-bit to check the operation.
Edited 1 time(s). Last edit at 2020-01-10 11:30 by maki.
#12 Re: Failure error meesage
Posted by: pspad | Date: 2020-01-10 11:32 | IP: IP Logged
Download it from the same address as you downloaded 64b version and replace EXE.
#13 Re: Failure error meesage
Posted by: maki | Date: 2020-01-10 12:56 | IP: IP Logged
I tested 32-bit. The error did not occur.
#14 Re: Failure error meesage
Posted by: pspad | Date: 2020-01-10 13:00 | IP: IP Logged
Thank you for info
#15 Re: Failure error meesage
Posted by: maki | Date: 2020-01-10 13:32 | IP: IP Logged
The error occurs in a 64-bit executable file.
#16 Re: Failure error meesage
Posted by: pspad | Date: 2020-01-10 14:21 | IP: IP Logged
Download and test this 64b build. Let me know if it still generates error.
mysharegadget.com
#17 Re: Failure error meesage
Posted by: maki | Date: 2020-01-10 15:48 | IP: IP Logged
mysharegadget.com
There is no error here.
What has changed?
Edited 1 time(s). Last edit at 2020-01-10 15:50 by maki.
#18 Re: Failure error meesage
Posted by: pspad | Date: 2020-01-10 16:00 | IP: IP Logged
I changed destry PSPad event.
Thank you for confirmation. This will be part of future builds.
