You are here: PSPad forum > English discussion forum > Re: CrashDumps
Posted by: maki | Date: 2020-01-08 15:08 | IP: IP Logged
The new PSPad update (360) crashes
C:\Users\XXX\AppData\Local\CrashDumps
Need these files for debugging?
Example:
PSPad.exe.XXXX.dmp
Edited 1 time(s). Last edit at 2020-01-08 15:09 by maki.
Posted by: pspad | Date: 2020-01-08 15:19 | IP: IP Logged
Windows crash dump doesn't hepl me.
Do you use 32b or 64b PSPad?
can you describe your activity when PSPad crashed? I must be able to simulate it to find problem.
Edited 1 time(s). Last edit at 2020-01-08 15:19 by pspad.
Posted by: maki | Date: 2020-01-08 17:06 | IP: IP Logged
64Bit
I installed the new version. Open several txt files in tabs, close applications and all time crash. That's all I do.
