You are here: PSPad forum > English discussion forum > Re: 5.0.3 PSPad change encoding - not work!
#1 5.0.3 PSPad change encoding - not work!
Posted by: maki | Date: 2019-12-28 19:28 | IP: IP Logged
Open HTML
Encoding -> 1251 (Russian)
It doesn't change anything.
In another editor, the change works, so it's a bug in PSPad
i.postimg.cc
Example:
âîçěîćíîńňü
#2 Re: 5.0.3 PSPad change encoding - not work!
Posted by: maki | Date: 2019-12-29 09:59 | IP: IP Logged
Please add the function: Auto-encoding Detect, without having to choose the default encoding between UTF-8, 1251 and 1250 all the time
Files and Dirs -> Default CP for files opening xxx
Please fix this bug:
Edited 1 time(s). Last edit at 2019-12-29 10:04 by maki.
#3 Re: 5.0.3 PSPad change encoding - not work!
Posted by: pspad | Date: 2019-12-29 10:21 | IP: IP Logged
This settings is for new file, see the help.
#4 Re: 5.0.3 PSPad change encoding - not work!
Posted by: pspad | Date: 2019-12-29 10:23 | IP: IP Logged
If you want to switch on autodetect encoding, do it in encoding menu. The option is there, click on it.
If you load page with wrong encoding, change proper encoding from menu and reload document (Ctrl+R).
