You are here: PSPad forum > English discussion forum > File without extension
Posted by: Lolo Irie | Date: 2019-10-09 13:05 | IP: IP Logged
sorry if it was already asked, I was not able to find any infos about...
Is it possible to save a file WITHOUT any extension ?
PSPAD alrady adds the .txt by default.
Thanks
Posted by: Lolo Irie | Date: 2019-11-08 08:11 | IP: IP Logged
no way to save without file extension ?
Cheers
Posted by: pspad | Date: 2019-11-08 08:36 | IP: IP Logged
Hello.
I will investigate, how to do it. I must try it.
Posted by: Vany | Date: 2019-11-08 10:14 | IP: IP Logged
hi, confirmed that PSPad saves always with an extension, defaulted to ".txt" even if you explicitly change the mask to *.* and save something like "somefilename." (with the dot at the end)
Posted by: pspad | Date: 2019-11-08 10:43 | IP: IP Logged
Yes, I tested it. Unfortunely it needs code fix.
After fix (in next developer build) when you change filter to *.* in default you will save file without extension.
Posted by: pspad | Date: 2019-11-08 10:46 | IP: IP Logged
For now only workarround is to create user highlighter, add file mask *. (nothing else can be done) and use this highlighter for editing files
Posted by: Vany | Date: 2019-11-08 11:26 | IP: IP Logged
It works!
Funny thing is that the files without an extension are automatically opened with the (in my case) EmptyExt highliter
Posted by: Lolo Irie | Date: 2020-01-31 11:03 | IP: IP Logged
Thanks for the answer and probably the fix.
I had now the the dev Version 5.0.3 (371) and want to "change filter to *.* in default" like you wrote... but not sure what you are meaning here.
In Settings, Files and Dirs, New default, I don't have an option *.*
If I choose *.* when I save a file, extension .txt is added.
Thanks for a short info for dummy people like me.
Posted by: pspad | Date: 2020-01-31 11:05 | IP: IP Logged
In the save dialog change file type to *.* (under file name).
Posted by: Lolo Irie | Date: 2020-01-31 12:07 | IP: IP Logged
I get always the .txt extension added
Don't matter if I choose the otion Save or Save as...
