You are here: PSPad forum > English discussion forum > Re: Code Explorer Memory Leak
Posted by: jballi | Date: 2019-08-30 17:35 | IP: IP Logged
PSPad v5.02 (319). May be other versions.
I've been using this version of PSPad since bugs with Code Explorer for AutoHotkey were fixed. The program runs well for a while but eventually it issues a fatal error message (I always forget to write it down). I'm always able to save the latest changes before shutting down the program so no harm, no foul.
A few days ago I noticed that the program was using a huge amount of memory (900 MB+). I closed all of the files I was editing but there was no change to the amount of memory used. I closed PSPad and opened it back up and the program was using a normal amount of memory. On my computer, it's ~35 MB.
Today I think I tracked down the leak. It's Code Explorer. Every time I hit the "Refresh" button on the Code Explorer panel, the program eats up ~2 MB more of memory. Every time I save a file, the Code Explorer view is refreshed so for me, a Code Explorer refresh occurs many many times a day. Eventually something maxes out and a system error message is issued.
Anything you can do to fix this problem would be appreciated.
Posted by: pspad | Date: 2019-08-30 17:59 | IP: IP Logged
Thank you for report. I will try to investigate it.
