You are here: PSPad forum > English discussion forum > How to extract the number of instances of a given number from 01 to 80 in separate lines
#1 How to extract the number of instances of a given number from 01 to 80 in separate lines
Posted by: maki | Date: 2019-07-01 21:19 | IP: IP Logged
How to extract the number of match of a number from 01 to 80 in separate lines:
Example:
Input:
01
01
01
01
01
02
02
03
03
03
04
05
06
06
06
06
06
06
06
06
Output (CSV Comma Separated):
01,05
02,02
03,03
04,01
05,01
06,05
Edited 3 time(s). Last edit at 2019-07-01 21:25 by maki.
#2 Re: How to extract the number of instances of a given number from 01 to 80 in separate lines
Posted by: Stefan | Date: 2019-07-02 07:22 | IP: IP Logged
maki:
How to ...
You have to write a script for that (or find a dedicated tool)
#3 Re: How to extract the number of instances of a given number from 01 to 80 in separate lines
Posted by: maki | Date: 2019-07-02 10:50 | IP: IP Logged
Stefan - There are thousands of different tools on softpedia.com, but I have not found a single tool that would allow different manipulations on numbers.
#4 Re: How to extract the number of instances of a given number from 01 to 80 in separate lines
Posted by: maki | Date: 2019-07-02 11:02 | IP: IP Logged
Or maybe add two options:
Multiline RegEx AND Multiline None and MultiCount Matches
Edited 1 time(s). Last edit at 2019-07-02 11:02 by maki.
#5 Re: How to extract the number of instances of a given number from 01 to 80 in separate lines
Posted by: Vany | Date: 2019-07-04 06:58 | IP: IP Logged
use Pivot tables in some spreadsheet if you don't mind to script it by yourself
(PSPad 5.5.1.790 x32, W10h/p x64 en/cs)
