You are here: PSPad forum > English discussion forum > Re: Cursor issue
Posted by: maki | Date: 2019-06-23 15:16 | IP: IP Logged
How to set a blinking cursor:
a) Beyond any character
b) Reduce its size
Posted by: pspad | Date: 2019-06-23 15:21 | IP: IP Logged
Program settings / Editor 2
Insert mode cursor
Posted by: maki | Date: 2019-06-23 15:40 | IP: IP Logged
And how to set a color Cursor?
Red, gumigota, razzmatazz, peridot, xanadu, feldrau and hgkh
Edited 1 time(s). Last edit at 2019-06-23 15:46 by maki.
Posted by: pspad | Date: 2019-06-23 15:58 | IP: IP Logged
Caret (cursor) is system thing. Set red cursor in Windows and you will have it in PSPad too
Posted by: maki | Date: 2019-06-23 19:32 | IP: IP Logged
Hm.
Notepad++ has a cursor in the color "purple". And yet another editor has a red cursor, it perfectly distinguishes it in the text. But you can also freely change the colors of anything, there are many option in setting to choose from. So you do not have to modify anything in the System. Well, unless you manage to change something in PSPad.
Edited 1 time(s). Last edit at 2019-06-23 19:36 by maki.
Posted by: waterloo5099 | Date: 2019-07-29 17:12 | IP: IP Logged
pspad:Caret (cursor) is system thing. Set red cursor in Windows and you will have it in PSPad too
How do I change the color in Windows 7? I've gone through every conceivable area, including Ease of Access Center, but have found no option to change the color of the blinking cursor.
Also, would it be possible to request blinking cursor thickness/color change options for a future revision of PSPad?
Love the program. Keep up the good work.
Posted by: viplex | Date: 2019-08-06 07:09 | IP: IP Logged
it should be in Control Panel > Mouse Properties > Pointers.
Best regards
