You are here: PSPad forum > English discussion forum > Convert to repeating names in links
Posted by: pspad | Date: 2019-06-22 09:44 | IP: IP Logged
Search: \/(\d+)\-
Replace: website.eu
Cause forum engine makes a link, copy replace link as result
Edited 2 time(s). Last edit at 2019-06-22 09:45 by pspad.
Posted by: maki | Date: 2019-06-22 10:19 | IP: IP Logged
Incorrect regular expression because invalid output:
Posted by: pspad | Date: 2019-06-22 12:44 | IP: IP Logged
I prepare result for your example.
You didn't provide correct example as usually. You are not able to modify provided example for your purposes. Your typical answer is that regular expression result is different from your expectation.
Sorry, but you need to find another person who will waste time with you.
Posted by: maki | Date: 2019-06-22 13:21 | IP: IP Logged
wherever I put a question mark should be
? -> [a-z0-9-]
https:\/\/website\.eu/[a-z-]/[0-9]\-[a-z0-9-]/.html
Edited 1 time(s). Last edit at 2019-06-22 13:24 by maki.
