You are here: PSPad forum > English discussion forum > Error Regex
Posted by: maki | Date: 2019-04-30 14:09 | IP: IP Logged
An attempt to repeat something that can not be repeated in the regular expression
Include char:
Edited 2 time(s). Last edit at 2019-04-30 14:11 by maki.
Posted by: vbr | Date: 2019-04-30 18:15 | IP: IP Logged
maki:An attempt to repeat something that can not be repeated in the regular expression
Include char:
You need to escape the regex metacharacters, if they should be matched literally
most likely, you need
instead of ?
in the above pattern.
note, that alternation of single characters is the same as character set, i.e. [.!?]
hth,
Edited 1 time(s). Last edit at 2019-04-30 18:17 by vbr.
