You are here: PSPad forum > English discussion forum > Re: Why my cmd window disappeared?
Posted by: algo | Date: 2019-04-25 07:35 | IP: IP Logged
I am using PSPAD under WINDOWS 10.
I used to execute pdflatex within PSPAD.
PSPAD will popup a command window which I can response.
But from some times ago, such window disappeared.
I don't know where did I made a mistake?
Posted by: pspad | Date: 2019-04-25 07:37 | IP: IP Logged
Do you use compiler or external application settings to run your PDFlatex?
Posted by: Stefan | Date: 2019-04-25 07:50 | IP: IP Logged
algo:I used to execute ...
How do you do that exactly?
Post here your used command.
