You are here: PSPad forum > English discussion forum > How do you open multiple files at once?
Posted by: maki | Date: 2019-03-27 23:26 | IP: IP Logged
Eg 100 text files with a total size: 2000 MB (2 GB)
I tried the best 64-bit Editors and can not do it.
Failure every time and using huge amounts of RAM, which can immediately end up with a computer crash (100% RAM [12GB] + 100% Virtual Memory 12000MB)
Edited 1 time(s). Last edit at 2019-03-27 23:27 by maki.
Posted by: pspad | Date: 2019-03-28 06:12 | IP: IP Logged
I will celebrate day when you will give all information in your question
What way do you use to open your files?
Command line?
PSPad open dialog?
Context menu over selected files in explorer or any manager and if yes, how is PSPad intgrated into context menu. Using DLL or registry?
Posted by: maki | Date: 2019-03-28 09:23 | IP: IP Logged
I just wanted to open several larger text files 20M-300MB.
Simple! Open PSPad. I drag all text files (31 files) to the application, I need to confirm every time: "It's sure you want to open ..."
But unfortunately it does not always work in PSPad and in all other TXT Editor, always errors, CRASH
https:// i.postimg.cc/8CjhDSgx/Screen-Shot-03-28-19-at-10-21-AM-001.jpg
Exception description:
Exception address:
Stack list, generated 28/03/19 10:20:57
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (251)
System : Windows 7 Professional x64, Version: 6.1, Build: 1DB1, Service Pack 1
Processor: Intel, Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz, 3500 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_36"
Edited 1 time(s). Last edit at 2019-06-07 18:50 by Stefan.
