You are here: PSPad forum > English discussion forum > Re: How to fix the coding into Polish letters?
Posted by: maki | Date: 2018-12-10 16:39 | IP: IP Logged
How to fix the coding into Polish letters? (charset fix). I need a regex to change all the characters throughout the text.
Mini-example:
CODE: SELECT ALL
Na drodze mojej sstanąłes. Pojawiles się z nikąd. Żeśmy się
Posted by: maki | Date: 2018-12-10 16:41 | IP: IP Logged
ALL POLISH LETTERS ARE DISTORTED, WANT TO ALL REPAIRS IN A BIG TEXT FILE.
Posted by: pspad | Date: 2018-12-10 17:09 | IP: IP Logged
Your file is in UTF-8, but there is some problem - not all characters are correctly encoded.
Change code page to UTF-8 manually (menu Encoding or clicking on the code page name on statusbar) and reload document - Ctrl+R
Posted by: maki | Date: 2018-12-11 09:35 | IP: IP Logged
pspad:Your file is in UTF-8, but there is some problem - not all characters are correctly encoded.
I tried, but it will not fix charset letters.
www.w3schools.com
How to remove 100% html code without losing coding of Polish letters. All tools, even with UTF-8 set to damage all Polish letters.
This program damages Polish letters, even though I set UTF-8 and does not delete 100% of the code.
HTMLAsText v1.11 - HTML to text freeware converter
Edited 2 time(s). Last edit at 2018-12-11 09:38 by maki.
Posted by: maki | Date: 2018-12-11 09:46 | IP: IP Logged
It is not possible to delete a simple HTML code in any way without damaging Polish letters?
I am looking for a solution for several years without success, all the most popular editors PROBLEM display correctly coding. All tutorials on various coding forums do not solve my coding problem. What's next?
I do not want to do it manually (copy / paste), because it will take ages, because I have a lot to convert HTMLtoTXT.
Each damaged character is assigned one letter. I need only a special regex that will automatically convert the damaged letters to the correct one. There used to be a great tool for repair, but I do not remember the tool anymore, and I do not remember the regex.
Posted by: pspad | Date: 2018-12-11 11:51 | IP: IP Logged
The easiest way how to get HTML text without HTML code is display page in browser and copy text.
You can try function in PSpad - open file from internet, you will get HTML source and than use from menu HTML / conversion - remove HTML tags
Posted by: maki | Date: 2018-12-11 15:11 | IP: IP Logged
It works, but not fully, because I want to extract specific text between specific tags.
And how to change it in 10,000 text files at the same time? Possible?
Edited 1 time(s). Last edit at 2018-12-11 15:12 by maki.
