You are here: PSPad forum > English discussion forum > Re: Word selection
Re: Word selection
#1 Word selection
Posted by: sati32 | Date: 2016-03-05 08:50 | IP: IP Logged
I double click on a word, it is selected by PSPad. I hold the mouse button clicked and drag, all my editors select the next word now, but PSPad won't. Is there an option for this?
#2 Re: Word selection
Posted by: BigBen | Date: 2020-01-22 17:42 | IP: IP Logged
I'm also interested by this double-click selection and have the exact same problem, PsPad is the only application I use that behaves as decribed. Is it a bug, a feature, something that I can change with some parameter (I searched but didn't find one)?
I would love to have PsPad behave like other applications in this respect.
#3 Re: Word selection
Posted by: pspad | Date: 2020-01-22 18:38 | IP: IP Logged
Just tested. If you dblclick, press shift and drag over text and you will end, whole word is slected when you release mouse button.
So difference is only that whole word isn't marked during dragg, but the result is same.
Edited 1 time(s). Last edit at 2020-01-22 18:42 by pspad.
#4 Re: Word selection
Posted by: Vany | Date: 2020-01-27 13:12 | IP: IP Logged
It works as reported.
Expected behavior is you dblclick a word and before releasing the mouse button (just second mousedown event handled) you drag the cursor over text, it has to expand the text selection by words (mouseover) until you release the button (mouseup).
Currently it just select the only word the mouse was dblclicked at.
#5 Re: Word selection
Posted by: pspad | Date: 2020-01-27 14:48 | IP: IP Logged
I understand. But it's limitation of editor component.
I can try to change behavior, but I can't promise I will be successfull.
PSPad work this way:
dblclick on word, pres Shift and click on end word. It will make same result, you only don't see it when you dragging.
Just now I have problem with HEX editor component and UNDO, I spend many hours with this issue yet and it isn't fixed yet.
Edited 1 time(s). Last edit at 2020-01-27 14:50 by pspad.
