You are here: PSPad forum > English discussion forum > Re: PSPad "portable" not in context menu?
Posted by: Compu_Terminator | Date: 2012-10-04 17:30 | IP: IP Logged
i've a little problem. Since 2 days, i don't use the installer version, rather the "portable" version. I don't succeed (false word?), that PSPad is in context menu. I've put it into the "send to" menu and into the "open with" menu, but i can't easy use the compare function.
Settings in 'system integration' are right.
Can anyone of you tell me, what i can more try? If not, i'll swap to installer version again.
I'll be very grateful for every kind of answer.
Best wishes, Andreas
PS: Nevertheless, PSPad is my preferred editor for PHP, JavaScript and CSS.
Posted by: pspad | Date: 2012-10-04 20:34 | IP: IP Logged
Use registry way to set PSpad into Context menu.
If you want to use Context menu handler DLL, you need run PSpad as administrator
Posted by: Compu_Terminator | Date: 2012-10-05 12:59 | IP: IP Logged
thanks for your answer, but i'm only a simple web scribbler. In settings, i've settet 'PSPad show in context menue' and 'dll', but it doesn't show. Maybe, my windows installation make this problem.
Now, i've reinstalled PSPad installer version, have had copied the newest release into program directory and i'm happy (like the 4 years before).
Thanks again for your help.
Be in touch, Andreas
