You are here: PSPad forum > English discussion forum > Re: pspad dont detect extentions
Posted by: Alex | Date: 2012-08-20 10:58 | IP: IP Logged
I've downloaded development build of pspad, and tried to install extention to it (zen coding). It doesn't see it. After that i install full stable version of pspad - it doesn't see it too. Even with sample extention i wrote myself.
How can i force extention detection? (In past there was a button for it, now i can't see it).
Posted by: vbr | Date: 2012-08-20 11:24 | IP: IP Logged
Alex:I've downloaded development build of pspad, and tried to install extention to it (zen coding). It doesn't see it. After that i install full stable version of pspad - it doesn't see it too. Even with sample extention i wrote myself.
you may check the settings:
System integration: [x] Integrated scripting support (WSH)
possibly it could have been deactivated somehow?
Which pspad build and windows version are you using? (There might be some security settings of the OS, which could be relevant too.
hth,
Posted by: Alex | Date: 2012-08-20 13:55 | IP: IP Logged
Thank you. It helps! Now I can see the scripts menu.
Posted by: Alex | Date: 2012-08-20 13:56 | IP: IP Logged
I'm using winXP. I downloaded file from here
forum.pspad.com
