You are here: PSPad forum > English discussion forum > New version of Silk toolbar
Posted by: MrSpock | Date: 2010-09-14 22:04 | IP: IP Logged
Good work, thanks a lot!
Posted by: MrSpock | Date: 2012-10-09 22:09 | IP: IP Logged
Another update of the Silk toolbar. New Google icon.
Posted by: pspad | Date: 2012-10-10 08:10 | IP: IP Logged
Thank you
Posted by: MrSpock | Date: 2015-12-30 19:01 | IP: IP Logged
Hi everybody,
After three years I felt I had to update the Silk toolbar and replace the Windows OS and the Google icons with newer versions.
Download the new Silk toolbar from Google Drive. Do not right-click the image, this will only download a JPEG preview. Instead, use the arrow icon at the top center of the page to download the BMP file.
Posted by: pspad | Date: 2016-01-02 11:12 | IP: IP Logged
Thank you. Are you able to make toolbar with 24x24 resolution? It will be good for high DPI.
Posted by: MrSpock | Date: 2016-01-02 12:33 | IP: IP Logged
Yes, I'll see what I can do, but it will probably take a few days.
Posted by: pspad | Date: 2016-01-02 17:40 | IP: IP Logged
MrSpock:Yes, I'll see what I can do, but it will probably take a few days.![]()
Thank you. I know it will, I painted current PSPad icons manually.
Posted by: billh78 | Date: 2016-01-07 14:14 | IP: IP Logged
pspad:HelloThank you. Are you able to make toolbar with 24x24 resolution? It will be good for high DPI.
I am also interested in creating a new tool bar. Is there some place where each of the 147 icons is documented? While the icons are there and I can find most of them in the PSPad menus and tool bars, there are some that I simply don't see. It may be that they are a part of a function dialog window.
I have looked through your documentation on this site and can't find what action each icon represents.
Posted by: pspad | Date: 2016-01-07 14:48 | IP: IP Logged
No, there isn't any description - simple lack of time. Some icons are displayed as changed state e.t.c.
Write me icons you are interested for, most of them I will be able to answer you, for the rest I must look for.
ICON strip is created as squares with same height and width. PSPad accepts automatically any size.
Background must be one color for all icons, use color what isn't used in any icon.
Edited 1 time(s). Last edit at 2016-01-07 14:50 by pspad.
Posted by: MrSpock | Date: 2016-01-08 20:03 | IP: IP Logged
Preview of the 24 pixel version:
[img=http://s16.postimg.org/s787fzpxd/pspad_silk_toolbar.jpg]
