You are here: PSPad forum > English discussion forum > Backup of open tabs
Backup of open tabs
#1 Backup of open tabs
Posted by: syntech | Date: 2019-02-14 14:55 | IP: IP Logged
I've used the search function, but couldn't find an answer. How can I enable automatic backup of the open tabs (files)? PSPad seems to save this info only when it's closed. But if I have to kill it, all currently open tabs are lost. If this feature doesn't exist, please consider adding it in the future. Would be very helpful for me! Thanks.
#2 Re: Backup of open tabs
Posted by: Andreas | Date: 2019-02-14 15:56 | IP: IP Logged
+100 Yes, would be a good idea to store the open tabs somewhere before a crash occurs.
#3 Re: Backup of open tabs
Posted by: pspad | Date: 2019-02-14 16:11 | IP: IP Logged
Just now there is a session function.
You can anytime save/restore session
I can add automatic session saving
#4 Re: Backup of open tabs
Posted by: Gabriel_ACE | Date: 2019-02-14 17:39 | IP: IP Logged
yes!! please! smiling smiley
#5 Re: Backup of open tabs
Posted by: syntech | Date: 2019-02-15 10:42 | IP: IP Logged
Session == all currently open tabs? Anything else?
And yes, automatic saving of all currently open tabs would be GREAT, because I never know when PSPad hangs/crashes and I have to kill it. With many (frequently changing) files open this is a PITA when this happens.
#6 Re: Backup of open tabs
Posted by: pspad | Date: 2019-02-15 11:11 | IP: IP Logged
Each file state is stored in the project or in file cache (PSCache5.bin) if enabled in program settings / Files
File state means cursor position, bookmarks, code page, highlighter.
#7 Re: Backup of open tabs
Posted by: pspad | Date: 2019-02-16 17:30 | IP: IP Logged
For the start I will save open file list after any file close or open.
Wee will see it it will be enough.
#8 Re: Backup of open tabs
Posted by: syntech | Date: 2019-02-18 08:55 | IP: IP Logged
Agreed, that's better than what we have now. But how about a timer like for the automatic backup?
"File state means cursor position, bookmarks, code page, highlighter."
For my needs everything of the listed options would be very helpful, but cursor position would be the most useful. Of course, I take what I get (a big thanks in advance!) but if automatic session save would be possible and it would be the same like when closing the editor (in my case, I save everything) it would be great!
#9 Re: Backup of open tabs
Posted by: pspad | Date: 2019-02-18 09:13 | IP: IP Logged
There is the timer for field autosave already in the program settings / Backup
#10 Re: Backup of open tabs
Posted by: syntech | Date: 2019-02-18 13:15 | IP: IP Logged
I know. I only mentioned this timer as suggestion for the 'tabs/session save' auto-save. What I meant was, instead of saving every file open/close add a timer like you did for the automatic backup. Sorry for the confusion.
