You are here: PSPad forum > English discussion forum > Regex issue (percentages)
Goto Page: 1 2 3 Next
#1 Regex issue (percentages)
Posted by: maki | Date: 2018-06-24 15:34 | IP: IP Logged
How to find percentages:
0 to 99.9%
Please corect regex
[0-99,9%]
Ignore the value 100%
#2 Re: Regex issue (percentages)
Posted by: pspad | Date: 2018-06-24 15:58 | IP: IP Logged
Do you really think you can enter interval 0%-99,9%? Regular expressions search for text expression, they doesn't evaluates mathematical expresions, functions e.t.c.
try something like this:
\d{1,2}(\.\d{1,2}%|%)
#3 Re: Regex issue (percentages)
Posted by: maki | Date: 2018-06-24 16:17 | IP: IP Logged
How to find all values from the range:
0% - 99.9%
Does not work properly:
#4 Re: Regex issue (percentages)
Posted by: maki | Date: 2018-06-24 16:40 | IP: IP Logged
in a text file
#5 Re: Regex issue (percentages)
Posted by: pspad | Date: 2018-06-24 17:12 | IP: IP Logged
maki:
0% - 99.9%
What does it mean "doesn't work properly"? Any example of your text what wasn't found? We don't see your file. If you want proper answer, you need give as enough information
#6 Re: Regex issue (percentages)
Posted by: maki | Date: 2018-06-24 18:55 | IP: IP Logged
R:\lkjghgK hJKhsym\-13974757_348284311.jpg -> I:\zekno-15076373\-13974757_348284311.mp3 - Kopiowanie zakończone powodzeniem 97%
Z:\BK ym\-15076373\-13974GGHJJD5348284311.jpg -> I:\Blask\-150373\13974757_348284311.mp3 - Kopiowanie zakończone powodzeniem 100%
Find every text in the lines in which all the values are from 0% to 99.9%, skip all of 100%
#7 Re: Regex issue (percentages)
Posted by: pspad | Date: 2018-06-24 19:23 | IP: IP Logged
If procent number is on new line, add ^ on the begin of reg.expression
^\d{1,2}(\.\d{1,2}%|%)
#8 Re: Regex issue (percentages)
Posted by: aGerman | Date: 2018-06-24 21:24 | IP: IP Logged
I think you were almost right, Jan. The only thing missing is that there must not be a digit or a point in front of your pattern.
[^\d\.]\d{1,2}(\.\d%|%)
Steffen
#9 Re: Regex issue (percentages)
Posted by: pspad | Date: 2018-06-25 04:12 | IP: IP Logged
If you exclude first char, you need to limit orrurence from zero or add case
(^|[^0-9])....
or
\d{0,}...
or it won't work on the begin of line
#10 Re: Regex issue (percentages)
Posted by: aGerman | Date: 2018-06-25 13:32 | IP: IP Logged
Absolutely right. But provided the example lines above are taken out of the real file then the percentage is rather on the end of the line winking smiley
Steffen
Edited 1 time(s). Last edit at 2018-06-25 13:33 by aGerman.
