You are here: PSPad forum > English discussion forum > checking php syntax
Posted by: twiglet | Date: 2014-09-12 10:38 | IP: IP Logged
Is there any way I can check for syntax errors in my code within pspad?
Posted by: pspad | Date: 2014-09-12 10:41 | IP: IP Logged
PSPad doesn't contains PHP server. You can use any external PHP commandline and set it as external application or compiler and call it to check your file
Posted by: pspad | Date: 2014-09-12 10:44 | IP: IP Logged
Open PSPad help and go to Menu description / Settings menu / Highlighter settings /Compiler settings / Compiler examples
There is example how to set PHP.EXE to check your syntax from PSPad
