You are here: PSPad forum > English discussion forum > remove "bold" from code explorer
Posted by: Aron | Date: 2006-06-30 13:08 | IP: IP Logged
Hi all!
I started to work with pspad one week ago and set it up nearly completely but the function list in the code explorer is still confusing me.
Is there a possibility to remove that "bold" marking for functions in that list? I did not find that option...
An other issue with the code explorer is that the button "set focus..." seems not to have any effect...
Posted by: pspad | Date: 2006-06-30 13:29 | IP: IP Logged
Button SetFocus - if is pressed and you click in the code explorer, cursor is moved into editor. If not presses, cursor stays in the code explorer
Posted by: Quicker | Date: 2013-11-11 20:24 | IP: IP Logged
an old one...
still a good question:
Posted by: Quicker | Date: 2014-09-09 20:49 | IP: IP Logged
Jan, while you change the autorefresh from the other thread (which I added today) can you also add a setting to switch off the bold marking in the code explorer?
Thank you.
Posted by: pspad | Date: 2014-09-09 21:00 | IP: IP Logged
Bold are non empty folders. I will try to remove it without option in next build
