You are here: PSPad forum > České diskuzní fórum > Access violation
Access violation
#1 Access violation
Posted by: lazna | Date: 2016-09-03 15:03 | IP: IP Logged
Chyba pri volani z "Shell context menu"
Pokud v exploreru rightclicknu nad textovym souborem, tak nasledna volba "Upravit v PsPadu" levym tlacitkem vyvola chybu. Nicmene pokud ve vyvolanem dialogu klinu na 'OK' tak program neupadne ale pokracuje v cinnosti.
L.
Exception class:
Exception address:
Stack list, generated 3.9.2016 16:59:54
Thank you for your support!
(See forum.pspad.com)
Also please describe what you have done right before
and how often that error occurs.
Thanks
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 4.6.0 (2700)
System : Windows 7 Home Edition x64, Version: 6.1, Build: 1DB1, Service Pack 1
Processor: Intel, Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz, 2890 MHz MMX
Display : 1680x1050 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_42"
Edited 1 time(s). Last edit at 2017-02-16 11:54 by Stefan.
