You are here: PSPad forum > České diskuzní fórum > chyba
Posted by: 4ever | Date: 2016-03-14 22:03 | IP: IP Logged
Dneska mi krachnul PSPAD. Nevím jestli vás to zajímá, pokud ne tak to smažte.
Exception address:
Stack list, generated 14.3.2016 23:01:01
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : P:\PROGRAMY\editory\PSPAD 6.0\PSPad.exe 4.6.0 (2700)
System : Windows XP Professional x32, Version: 5.1, Build: A28, Service Pack 3
Processor: AMD, AMD FX(tm)-8300 Eight-Core Processor , 3320 MHz MMX
Display : 800x600 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_18"
Edited 1 time(s). Last edit at 2019-06-07 18:56 by Stefan.
Posted by: pspad | Date: 2016-03-15 04:29 | IP: IP Logged
Visit PSPad forum and download the latest build 4.6.1 from PSPad
developer forum: www.pspad.com
Replace existing files with content of archive.
This build contains fix of your problem
Posted by: 4ever | Date: 2016-03-15 13:03 | IP: IP Logged
ok I did but PSPAd doesnt open php files now. I changed the folder name to pspad 6.1 now Windows cannot associate that file with pspad. For some reason it is not in the list of program to associate with. Clickin on that file will open it in notepad. Yet I submit Open With PSPad but PSPad is not added to the list of programs I am using. IDK if this is XP problem or your program problem
Edited 1 time(s). Last edit at 2016-03-15 13:05 by 4ever.
Posted by: pspad | Date: 2016-03-15 13:10 | IP: IP Logged
Change of the PSPad exe has no influence of the PHP file opening.
Can you tell me the way how do you open PHP files? Clicking in the explorer or ...
Posted by: 4ever | Date: 2016-03-15 18:09 | IP: IP Logged
Clicking in Explorer. This is the fastest way for me. I could use the dialog box in PSPad but I am used to Explorer. Offen I am using it for many reasons. I tried the *.js adding it to asssociation list with *.php. Only the .js files can be opened directly, but not the .php.
Update:
When I added .js files, the PSPad program appeared in the list of programs and I did not tried the php since then. So I tried it now because it is now in the list and the OS can find the PSPad now, so it is fine. I submited the file and it opens with PSPad now.
