You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2700) English
Posted by: janaco | Date: 2015-10-05 20:43 | IP: IP Logged
Thanks for the new Final.
Sadly since version 2669 up to this build in TXT-Files the Real Tabs (0x9) are always expanded to spaces when typing, even if the "Setting>Program Settings>Editor (part 2)>Real Tabs" is checked ([Config] RealTabs=1).
When explicitly unchecked and checked again it works, but after restart of PSPad RealTabs are gone again.
If different settings are applied to other highlighters, then RealTabs work there. But not for Default-Setting.
I reverted to Version 2667.
janaco
Posted by: pspad | Date: 2015-10-07 18:53 | IP: IP Logged
I found a problem and fix will be available in the next build.
As workaround, go to program settings / Program 2
Uncheck option Highlight URL address if no highlighter
