You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.0 (2700) English
Posted by: pspad | Date: 2015-10-02 16:19 | IP: IP Logged
Released full version
www.pspad.com
Posted by: PGomersall | Date: 2015-10-02 17:46 | IP: IP Logged
English file not available on server.
Posted by: pspad | Date: 2015-10-02 18:09 | IP: IP Logged
Which file isn't available?
PSPad460_setup.exe is international installer. If your Windows localization isn't Czech or Slovak, it will install english PSPad for you
Primary donwload offers installer and portable version
Mirror isn't updated yet, it has some delay. I guess it will be available tomorrow.
Posted by: tDJ | Date: 2015-10-02 18:31 | IP: IP Logged
The installer link on FossHub is corrupt (it can't find the file).
thedutchjewel.defcon5.biz
Posted by: PGomersall | Date: 2015-10-02 18:44 | IP: IP Logged
The links on fosshub point to nothing
Posted by: pspad | Date: 2015-10-02 19:31 | IP: IP Logged
it worked for me. FossHub has many servers in different locations. please be patient, they need some time to synchronize.
Posted by: pspad | Date: 2015-10-02 19:37 | IP: IP Logged
I temporary redirected mirror from Download3K to direct download.
Mirror download should work now.
I am sorry, but I am not able to cover download trafic from my primary site, cause it's hundreds of GB mothly.
Edited 2 time(s). Last edit at 2015-10-02 19:46 by pspad.
Posted by: PGomersall | Date: 2015-10-02 20:49 | IP: IP Logged
Jan - I emailed fosshub and then they fixed the link.
Posted by: Freeman | Date: 2015-10-04 00:09 | IP: IP Logged
Thanks for "Nastav pravy okraj pozici kurzoru", Jan. Didn't translate it yet.
But... how can I switch off previously set line? Pressing hotkey at the same position doesn't work.
And... Right edge disappears again, when cursor line set. Is it become new right edge? Right edge setting isn't changed.
IMHO, there can be two different features, each has two modes:
* Cursor line. May be persistent or temporary. Temporary is visible only when some key pressed (I've wanted this).
* Persistent vertical line (You done this). May be single or multiple. On/off by the key at the same position.
Right edge is third feature, separated from the both above.
Posted by: pspad | Date: 2015-10-04 06:47 | IP: IP Logged
I saw everything translated.
Look into language file you use for line:
aRightEdgeToCursor_Caption=
This string is contained if the full 4.6.0 version
It has no sence to use it with cursor line together. If you will set bot option on, you will see cursor line and setting right edge to cursor position you will set right edge to to same position as cursor line. When you move cursor, you will see both line again.
Cursor line is immediate line, it automatically follows cursor
Right edge is persistent for the position where you set it. When you open file, it appears on the position from program settings / Editor 2. When you click on the ruler or use shortcut for aRightEdgeToCursor, it will change position for current file and stay on this position up to you close file
There are 2 lines only.
