You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2661) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.6.0 (2661) English
Posted by: pspad | Date: 05/24/2015 19:02 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2660)
News
Find in files dialog - new switch on dialog which allows let dialog open after search
Calculate block - improved different number format handling
Code explorer for QBasic
File locking with R/O attribute with Save All function
Cancel answer during close process
#2 Re: PSPad unicode 4.6.0 (2661) English
Posted by: pythonui | Date: 05/25/2015 02:38 | IP: IP Logged
Thanks!
Working Great!! smiling smiley
#3 Re: PSPad unicode 4.6.0 (2661) English
Posted by: Bobf | Date: 05/28/2015 07:11 | IP: IP Logged
Hello Jan,
many thanks about the "Cancel answer during close process" it works perfect.
I have still another question.
PSPad can't open TXT files larger than 200 MB, because i get always an out-of-Memory on a Win7 64bit with 8GB RAM.
Is there any switch which i can turn on to open big files?
many thanks Bob
#4 Re: PSPad unicode 4.6.0 (2661) English
Posted by: pspad | Date: 05/28/2015 09:12 | IP: IP Logged
I don't have problem to open bigger files than 200MB.
32bit's application is limited by 2GB of RAM (OS limitation), unicode means 2 bytes per char.
Can you ZIP and upload any file you are not able to open and send me link to PSPad support mail?
#5 Re: PSPad unicode 4.6.0 (2661) English
Posted by: Bobf | Date: 05/28/2015 11:02 | IP: IP Logged
Hi Jan,
file sent.
Bob
#6 Re: PSPad unicode 4.6.0 (2661) English
Posted by: pspad | Date: 05/28/2015 12:39 | IP: IP Logged
You are right, PSPad isn't able open 500MB file.
First you need to load file into buffer, then allocate unicode string (2 times size of file) and use system function to recode your UTF-8 into unicode.
#7 Re: PSPad unicode 4.6.0 (2661) English
Posted by: Bobf | Date: 05/28/2015 12:52 | IP: IP Logged
Ok, would it be possible to enhance PSPAD to read such large files in UTF8 as well?
Bob
#8 Re: PSPad unicode 4.6.0 (2661) English
Posted by: human | Date: 05/28/2015 17:00 | IP: IP Logged
... simplest solution may be a 64bit version - or aren't the var types correct for a simple recompilation solving the issue?
I assume the problem is only with Unicote/UTF-8 files, plain text files should be able to be opened, aren't they?
#9 Re: PSPad unicode 4.6.0 (2661) English
Posted by: pspad | Date: 05/28/2015 17:38 | IP: IP Logged
First I need to update PSPad source to be compatible with new Delphi version. Next step will be compilation into 64 bits.
#10 Re: PSPad unicode 4.6.0 (2661) English
Posted by: human | Date: 05/28/2015 18:54 | IP: IP Logged
Sounds like year 2016, doesn't it?
What about plain ANSI text files, does it work to open 1,2GB files with current version?
