You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.9 (2503) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-14 08:37 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.5.8 (2501)
News
New PHP beautifier (http://www.waterproof.fr/products/phpCodeBeautifier/)
Code explorer - possibility Switch off refresh with File save in Program settings / Tools
HTML highlighter - fixed curly brackets highlighting in text with switched off template support
#2 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 07:45 | IP: IP Logged
New PHP beautifier did not work for me. No action at all on PHP files with PHP syntax highlighting. Did I miss something?
#3 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 08:13 | IP: IP Logged
Look at page:
www.waterproof.fr
There is explanation of switches and code modifying.
How is works:
1. PHP file must exists on disk, cause external tool needs file as parameter
2. File is sent to phpcb.exe with selected options as parameter and output is catched (similar way as compiler output)
3. current editor content window is replaced with catched output (with UNDO possibility)
#4 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 08:42 | IP: IP Logged
Win 7 64
PHP file to beautify is on disk and open in PSPad.
Unchanged PhpCBCFG.ini is in my PSPad folder root.
phpCB.exe is in my PSPad folder root.
Nothing happend!
Do I have to make some settings in my PHP highlighter on tab "External applications" or "Compiler"?
#5 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 09:04 | IP: IP Logged
No there isn't necessary to do any changes in settings.
The problem is described functionality to redirect output into file using ">" doesn't work so I need to use catch output.
Try to tun PHPCB.exe with some options on any your PHP file manually in DOS window
Edited 1 time(s). Last edit at 2014-09-15 09:05 by pspad.
#6 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 10:31 | IP: IP Logged
Yes, it works nice on command line
C:\Portable\PortableApps\PSPadPortable>phpCB.exe test.php > test_new.php
#7 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 10:44 | IP: IP Logged
I will try to find a reason. It works ok for me. I will try some workaround with generated BAT file
#8 Re: PSPad unicode 4.5.9 (2503) English
Posted by: pspad | Date: 2014-09-15 13:19 | IP: IP Logged
Can you please test this build:
www.dropbox.com
Replace current exe with exe from ZIP.
I changed mechanism to:
CMD file with temp name is generated to folder with original file with command to call PHPCB.exe
Output of Phpcb is redirected to file with temp name in same folder
Output from PhpCB is open in PSPad as new tab
temp batch and temp file are deleted
Can you confirm it works please?
#9 Re: PSPad unicode 4.5.9 (2503) English
Posted by: hhoefling | Date: 2014-09-15 14:06 | IP: IP Logged
Only an idee...
Under Windows 7/8
the programm excecution can be forbidden in Data folder.
Then the Batch File must be in an other location.
by HH
#10 Re: PSPad unicode 4.5.9 (2503) English
Posted by: Andreas | Date: 2014-09-15 14:27 | IP: IP Logged
OK here my results:
Before you sent me 2504 I tried to put
into my windows environment variable "path". This works (don't need to restart my windows).
But: Content of PHP file gets doubled
<?php
// my code
<?php
// my code
Second one is the original.
And: Cursor shows busy cursor when hover over toolbar menu icons until you click into editor text again.
And: There are some errors with indentations (wrong indentations)
2504:
I removed my path variable and tried 2504. It works.
But: Same double content and indentation bug.
And: Content ist shown in a new file where you have to watch out to not again use the PHP beautifier else PSPad hangs and has to be closed with the task manager.
ps I'm working with phpStylist in PSPad and this works much better - realy nice code formating like expected.
