You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.8 (2462) English
Posted by: pspad | Date: 2013-11-02 08:41 | IP: IP Logged
Manfred62:Avast has fixed this problem now
Thank you for confirmation.
Posted by: gwinkless | Date: 2013-11-04 13:14 | IP: IP Logged
Saving ANSI encoded files twice (and therefore erroneously popping up with a File Contents Were Changed" message) still exists in this version.
Did you see the investigation of that problem I did in this post)?
Posted by: Bolla | Date: 2013-11-04 14:41 | IP: IP Logged
Is it possible to have an option to disable the autocomplete after pressing space key?
Like in (not so) old versions .
Posted by: pspad | Date: 2013-11-04 15:12 | IP: IP Logged
Bolla:Is it possible to have an option to disable the autocomplete after pressing space key?
Yes, it will be implemented in the next build
Posted by: Bolla | Date: 2013-11-04 17:01 | IP: IP Logged
Thank you!
So I will wait till nex build to update
Posted by: francheu | Date: 2013-11-09 12:17 | IP: IP Logged
pspad:News
Added option to run external application with file or selected text (highlighter settings and project settings)
This option is really great, thank you so much Jan !
François
