You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2453) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-02-17 14:10 | IP: IP Logged
Download links (2.7 MB):
dl.dropbox.com
Changes to 4.5.7 (2450)
News
Code explorer for SDL
New TiDy.exe version with HTML5 support
New keywords in Cobol highlighter
New line comment style in user highlighter
Program settings / Backup - added information about PSPad config files path with possibility to open it in Windows Explorer
Some fixes for MAKE code explorer
Edited 2 time(s). Last edit at 2013-03-17 11:55 by pspad.
#2 Re: PSPad unicode 4.5.8 (2453) English
Posted by: Bobf | Date: 2013-02-20 07:10 | IP: IP Logged
Hi Jan,
any problems with the source location?
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Bob
#3 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-02-20 07:57 | IP: IP Logged
I will check it. One mirror has problem and now second one.
#4 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-02-20 08:03 | IP: IP Logged
Use temporary path:
www.pspad.com/files/pspad/pspad458b2453.zip
#5 Re: PSPad unicode 4.5.8 (2453) English
Posted by: Bobf | Date: 2013-02-20 10:15 | IP: IP Logged
many thanks, that's works.
Bob
#6 Re: PSPad unicode 4.5.8 (2453) English
Posted by: Shadeclan | Date: 2013-02-27 18:39 | IP: IP Logged
Use temporary path:
Thanks, Jan - Dropbox is blocked here.
Any changes in here, addressing that WINE problem I was having?
Edited 1 time(s). Last edit at 2013-02-27 18:46 by Shadeclan.
#7 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-02-27 19:28 | IP: IP Logged
I removed Formát in defailt menu item name. Try if it help you
#8 Re: PSPad unicode 4.5.8 (2453) English
Posted by: sandrosilveira | Date: 2013-03-11 14:03 | IP: IP Logged
I updated PSPad from 2441 to 2453 and our developers reported me that when they navigate through the source code by pressing key down or key up and keep pressed this key, while don't scrolling is happening much "flickering" or "blinking". Editor, ruler and number line areas are now redrawn always when line change.
Is easy to see this: in a dark background theme, for any file type, load a file, put the cursor at first line and navigate down by maintain pressed key down and you will notice that there is a strange visual behavior with constant redraw of PsPad interface, some text's lines sometimes disappear and turn to appear quickly.
This problem is critical when we use a slow remote terminal service connection, any screen redrawn or refresh in this scenario is very bad.
If you need I can record a video and send to you.
Thanks for your excelent work with this fantastic tool, I hope this can be easily fixed.
#9 Re: PSPad unicode 4.5.8 (2453) English
Posted by: miki | Date: 2013-03-11 14:15 | IP: IP Logged
sandrosilveira:
... "flickering" or "blinking"...
I reported this issue quite a long time ago (03.09.2012). I'm still using build 2447, which is the last build, where this flickering didn't occur.
#10 Re: PSPad unicode 4.5.8 (2453) English
Posted by: Shadeclan | Date: 2013-03-13 12:37 | IP: IP Logged
I removed Formát in [default] menu item name. [See] if it help[s] you
On the plus side, I finally got a chance to upgrade PSPad on my Kubuntu box and it worked great! Thanks again, Jan! W00t! smiling smileysmiling smileysmiling smiley
