You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2441) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.5.7 (2441) English
Posted by: pspad | Date: 03/13/2012 17:27 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.7 (2437)
News
added Code explorer parser for Makefile (ftMakeFile file type in User highlighter)
added V+ syntax user highlighter definition including Code explorer
User highlighter - added possibility to switch off string escaping
Show color - added possibility to lock all sliders
Open file apointed by selection function works with relative paths
User convertors - extended for unicode replacing. In section [Description] added UTF8List=0/1 option. Strings are stored in UTF-8 encoding
Changed memory manager. I hope it won't cause problems. Reposrt me any unexpected behavior.
Scripting - new function reloadClips - reloads all code clips
Fixed PSpad settings as IE viewer and IE compatibility
Block copy - fixed
FTP - fixed remove file extension in FTP client settings
Code explorer for PHP - function starts on Includexxxx was taken as include directive
Search in files doesn't work correctly with ignored folders (program settings / Files and dirs)
Fixed doubled menu items in script menu - state when operating system returns 2 same scripting engines
Show color - click on stored color doesn't update HTML color code
File information display problem on system with changed font size
#2 Re: PSPad unicode 4.5.7 (2441) English
Posted by: Skulstad | Date: 03/14/2012 09:58 | IP: IP Logged
The 'User highlighter - added possibility to switch off string escaping' has Czech label.
Regards,
Jorn Chr. Skulstad
#3 Re: PSPad unicode 4.5.7 (2441) English
Posted by: pspad | Date: 03/14/2012 11:10 | IP: IP Logged
Sorry, I forgot to update language files sad smiley
I will reupload this build again.
#4 Re: PSPad unicode 4.5.7 (2441) English
Posted by: carbonize | Date: 03/14/2012 13:10 | IP: IP Logged
Nah I'd leave it. Won't hurt people to learn another language ;)
Carbonize
#5 Re: PSPad unicode 4.5.7 (2441) English
Posted by: pspad | Date: 03/14/2012 13:14 | IP: IP Logged
Reuploaded
#6 Re: PSPad unicode 4.5.7 (2441) English
Posted by: tony72 | Date: 03/15/2012 16:52 | IP: IP Logged
Yay, you found this bug finally grinning smiley. Thanks for the new build.
#7 Re: PSPad unicode 4.5.7 (2441) English
Posted by: carbonize | Date: 03/15/2012 18:42 | IP: IP Logged
It was never a bug, it was down to IE9 creating two instances of the scripting engine so that when PSPad asked Windows what engines were available Windows would send a list which included the same engine twice and PSPad just listed what scripts were available for each engine returned. Now Jan just has it ignore duplicate engines.
Carbonize
#8 Re: PSPad unicode 4.5.7 (2441) English
Posted by: nergmlam | Date: 03/23/2012 13:09 | IP: IP Logged
Hi Jan
Is there any way to get automatically emails when you creates info about new builds in "Developer forum - new builds"
It wouldn't work if I enables "Send replies to this thread to me via email" on this topic
Sincerely
J. Malmgren
IT-Programmer
Denmark
Version 4.5.7(2441)
#9 Re: PSPad unicode 4.5.7 (2441) English
Posted by: pspad | Date: 03/23/2012 13:20 | IP: IP Logged
You can register to RSS chanel.
#10 Re: PSPad unicode 4.5.7 (2441) English
Posted by: Neil | Date: 03/26/2012 23:44 | IP: IP Logged
nergmlam:
This works fine for me.
Goto Page: 1 2 Next
