You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2445) English
Posted by: pspad | Date: 2012-04-09 17:09 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.7 (2441)
News
Drag/Drop image into HTML while CTRL is kept inserts image directly into code as BASE64 - it works from PSPad file explorer too
CSS highlighter - added new keywords
C++ code explorer - fixed problem with __fastcall
Posted by: carbonize | Date: 2012-04-10 07:56 | IP: IP Logged
Thanks for the update. I like th eauto base64 idea even though it's something I've never used in HTML.
Carbonize
Posted by: ok1 | Date: 2012-04-13 05:04 | IP: IP Logged
I'm still getting my 'Recently opened files' list cleared out with this version (like it was with version 4.5.7 2441).
Also I'm absolutely certain I did not select 'Clear recent files list'.
Have reverted to version 2437 like I did last time and no more clearing of the 'Recent files list'
Posted by: Anonymous User | Date: 2012-04-13 05:47 | IP: IP Logged
I can confirm this, and have returned to 2437.
Posted by: pspad | Date: 2012-04-13 07:06 | IP: IP Logged
I will look at this problem as soon as possible.
Posted by: ino | Date: 2012-04-13 07:41 | IP: IP Logged
pspad:I will look at this problem as soon as possible.
There is kept only one record (the very last opened file) in Recent.ini file.
Posted by: Anonymous User | Date: 2012-04-16 08:42 | IP: IP Logged
Hi. Version 2445: The 'Scripts' menu contains the Czech phrase 'Soubory v projektu'.
Posted by: carbonize | Date: 2012-04-16 10:02 | IP: IP Logged
Skulstad:Hi. Version 2445: The 'Scripts' menu contains the Czech phrase 'Soubory v projektu'.
Isn't that just the name of one of the scripts?
Carbonize
Posted by: Anonymous User | Date: 2012-04-16 12:43 | IP: IP Logged
Yes, your're quite right. Sorry.
Posted by: Pelle1911 | Date: 2012-04-18 08:08 | IP: IP Logged
thanks - the __fastcall problem went away - well done.
Another question:
in .H files (CPP-Header-Files), if I do
class TMyClass
everything is fine (in CodeExplorer).
But if I do
class TMyClass : TMyParent
CodeExplorer doesn't list TMyClass, but TMyParent as the class declared. I suppose that's not intended?
Regards,
Pelle.
