You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2433) English
Posted by: pspad | Date: 01/24/2012 20:05 | IP: IP Logged
francheu:Hi
I get PsPad crash when applying Format / Code case change...
This occurs only when a user-defined highlighter is used, it is OK for built-in highlighters.Can anybody confirm this issue ?
Confirmed. I will fix it
Posted by: francheu | Date: 01/26/2012 21:50 | IP: IP Logged
I have found another problem.
The file name is usually given as a parameter to an external application associated to a given highlighter (with F9), e.g. c:\prog.exe %file%.
If a part of the text is selected when lauching the external program, this selection is used as the %file% parameter instead of the file name.
I hope this is clear...
François
Posted by: pspad | Date: 01/26/2012 22:27 | IP: IP Logged
francheu:I have found another problem.
This is a intentional behavior. It's commonly used in e.g. SQL IDE's where selected test is runned. You mark command and run it.
Posted by: francheu | Date: 01/27/2012 20:49 | IP: IP Logged
pspad:This is a intentional behavior. It's commonly used in e.g. SQL IDE's where selected test is runned. You mark command and run it.
I thought it was a bug, now I see this as an interesting feature
Thanks !
François
Posted by: francheu | Date: 01/28/2012 19:38 | IP: IP Logged
For checkbox clips, the help manual says:
Pspad manual:@K = Checkbox
This produces a simple checkbox control. If the value of default is not blank then the control is initial checked.
However, even if something is put in the default value, the box always appears unchecked...
François
Posted by: pspad | Date: 01/29/2012 13:17 | IP: IP Logged
Posted by: pspad | Date: 01/29/2012 14:59 | IP: IP Logged
Fixed. I hope I will release new build today
