You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2381) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.5 (2381) English
Posted by: pspad | Date: 2010-01-07 20:53 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
Changes to 4.5.5 (2374)
News
Drag/Drop image to HTML file with CTRL key inserts Base64 image form direct into code
LOG parser - added %S what means any count of spaces/tabs
Direct HEX editor works with code switching in menu format (right column)
New script command: highlighter([s: string]): string sets/returns editor highlighter. You can enter start of the highlighter name only.
Show nonprintable chars - small dot for spaces
Editor Command ecInsert inserts new line before current line and place cursor to start of the line
PSPadShell extension first looks for PSpad in current folder then from registry - has meaning for multiuser environment
Included manifest - requestedExecutionLevel is set to asInvoker
JScript highlighter allows you highlight words begining of underscore with different color
Syntax change - new button to set TXT - remove highlighter from file
Fixes
Reformat XML code - handled CDATA section
PSpad doesn't take ShowHint settings (Program settings/Direct edit) after start
FTP keep connection keeps current folder and keeps FTP client connected
#2 Re: PSPad unicode 4.5.5 (2381) English
Posted by: MrSpock | Date: 2010-01-08 14:23 | IP: IP Logged
Thanks for the new build. Probably a small bug: When whitespace characters are displayed, the tab characters are now represented by a question mark.
#3 Re: PSPad unicode 4.5.5 (2381) English
Posted by: MrSpock | Date: 2010-01-08 15:10 | IP: IP Logged
Found another glitch. The following screenshots show how the positions of space characters are incorrectly displayed when visible whitespace is on:
#4 Re: PSPad unicode 4.5.5 (2381) English
Posted by: hamasaki | Date: 2010-01-08 16:09 | IP: IP Logged
Is the undo bug fixed in this build?
#5 Re: PSPad unicode 4.5.5 (2381) English
Posted by: massimobalestra | Date: 2010-01-08 16:39 | IP: IP Logged
By my fist test looks that also the undo bug is solved.
Thank you very much.
I love this program.
#6 Re: PSPad unicode 4.5.5 (2381) English
Posted by: stefangabos | Date: 2010-01-08 18:41 | IP: IP Logged
can you please make the auto indent feature so that it remembers it's auto indent for more than just one row? my coding style is so that i leave one blank line after each line (for better code readability) and once i get to the row i actually want to write in, the cursor is at position 1 in the line. please make it so that the auto indent feature is done according to the previous non-blank line. thanks!
#7 Re: PSPad unicode 4.5.5 (2381) English
Posted by: hamasaki | Date: 2010-01-08 19:23 | IP: IP Logged
massimobalestra:
Thanks massimobalestra. smiling smiley
#8 Re: PSPad unicode 4.5.5 (2381) English
Posted by: kiendlm | Date: 2010-01-08 20:32 | IP: IP Logged
massimobalestra:
I can't confirm this. Have you really tested this by editing a file with highlighter and autoindent enabled? In build 2374, when PSPad was configured this way the bug occurred every time when you press <CR> and then select "undo" or press CTRL+Z (i.e. when "undo" is selected immediately after an autoindent operation took place), and after several tests I must state that this has not changed with the current build 2381. I also think Jan would have pointed out in his release notes if he had fixed this bug.
#9 Re: PSPad unicode 4.5.5 (2381) English
Posted by: massimobalestra | Date: 2010-01-08 22:08 | IP: IP Logged
I am working with this last patch right now.
Autoindent is on and I was able to disable the "scroll past EOL and EOF".
I often insert characters and then undo. Everything seems to work correctly to me.
#10 Re: PSPad unicode 4.5.5 (2381) English
Posted by: hamasaki | Date: 2010-01-09 07:41 | IP: IP Logged
I`m holding off upgrading to any more versions until it seems ok. With the previous 2 builds I`ve reverted to back to previous versions.
h
