You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.5 (2373) English
Posted by: pspad | Date: 2009-11-08 18:32 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2370)
News
Fortran Code explorer shows CALL in procedure body
New commend line option /Snnn or -Snnn forced highlighter given by nnn. You can use start of highliter name only. Highlighter is used for all files in command line
In manifest was requestedExecutionLevel set to "highestAvailable" value
Corrections
Main window and more desktops
Icon was lost when you go to settings and files with iconsets was missing
Autoindent behavior corection
Code explorer for Cobol
Bracket highlighting in C++ and JScript
String highlighting in JScript
Fortran line comment in user highlighter takes 'C' only when on the first position in line
Exception after binary file reload
Posted by: Billy | Date: 2009-11-08 19:22 | IP: IP Logged
Why does UAC pop up when I start PSPad? Previous versions didn't trigger it.
Posted by: human | Date: 2009-11-08 20:03 | IP: IP Logged
Didn't you read the announcement?
pspad:In manifest was requestedExecutionLevel set to "highestAvailable" value
No idea why this was done, but it's cleary said.
What changes were done in code explorer for COBOL?
human
Posted by: pspad | Date: 2009-11-08 20:05 | IP: IP Logged
human:What changes were done in code explorer for COBOL?human
There was a problem with commented lines - they appears in code explorer in some cases
Posted by: carbonize | Date: 2009-11-08 20:57 | IP: IP Logged
Sorry but I hate this build. Having to rn PSPad with admin rights is going to put off many many users and is pointless. As I said in the other thread, "To be honest if you don't know that you need admin rights to edit files in certain system folders then you shouldn't be editing them files in the first place."
Also ths release has gone and totally replaced my syntaxhighlighting for PHP. I had the colours set how I want and now they have reverted back to the PSPad defaults.
I am not a happy person.
Carbonize
Posted by: carbonize | Date: 2009-11-08 21:05 | IP: IP Logged
OK got my settings back. For some reason this build switched to a single user enviroment when I had it set to multi user enviroment.
Still think you need to remove the UAC as it is not needed in a text editor.
Carbonize
Edited 1 time(s). Last edit at 2009-11-08 21:05 by carbonize.
Posted by: BloodSword | Date: 2009-11-08 21:24 | IP: IP Logged
Personally I have disabled the UAC completely. It makes
trouble, trouble and trouble. And it is nonesence 'cos
today malware is able to get admin rights even though UAC.
That's because they use security problems in software,
causing corrupt memory to get admin rights. There is
nothing UAC can do against it.
But I aggree, an Editor should never use admin rights.
If it does there is a problem with the user accounts.
Therefore Carbonize got problems with his settings...
The UAC makes something completely wrong:
Instead of elevate the rights, it runs the application
in a completely alternated user environement. So you
have other user variables, other user documents, other
user settings and other ntuser.dat registry.
As long as MS has not fixed that, I will N-E-V-E-R use
the UAC again.
For higher security: Use a hardware firewall, a free
antivirus software solution and - most important -
your brain.
Edited 1 time(s). Last edit at 2009-11-08 21:27 by BloodSword.
Posted by: pspad | Date: 2009-11-08 21:31 | IP: IP Logged
OK. I will do another modification. I will move windows manifest out of PSPad and let it as separate file.
All will be able to tune up it or remove it completely.
When we will find godd for of manifest, i will integrate it into PSPad.
Posted by: pspad | Date: 2009-11-08 22:23 | IP: IP Logged
Locked. Continue with the build 2374:
forum.pspad.com
This Thread has been closed
