You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2317) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-27 16:31 | IP: IP Logged
Download links (1.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.4 (2315)
Known issues
Slow file loading
News
Scripts - added function ftpRefresh() - refresh FTP folder. For ftpUploadFile() added 3-rd parameter - refresh folder after file upload
Scripts - added editor function modified([boolean]), sets or returns modified state
Code explorer for PureBasic
Session manager - possibility to set if new session keeps open files
Cobol higlighter - added JCL keywords, JCL comments are still not supported
LOG windows - possibility to set (common) font using font button in the LOG window
FTP connections - import FlashFXP exported accounts
PSPad remembers right dock panel width
Program setings / Dialogs - possibility to switch off close all files befre open project
PSPad now opens UTF-8 even it contains invalid characters
Corrections
multimedia keyboard support - switched CUT and COPY
compiled file was saved even wasn't modified
FTP - exception with CHMOD for folder
FTP - on some servers PSPad cuts first 2 chars from filename
e-mail highlighting doesn' count with ampersand char
HTML/RTF export doesn't use font from editor window
Favourite panel - bad icons if panel was empty
Print preview - file name instead file path in header
File tab - hint shows local path for files from FTP
Code explorer for PHP - public / private icons
Edited 2 time(s). Last edit at 2008-06-02 15:33 by pspad.
#2 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Funbug | Date: 2008-05-27 20:47 | IP: IP Logged
Works perfectly for me. Thanks! smiling smiley
#3 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Ilya | Date: 2008-05-28 05:22 | IP: IP Logged
How can I save another font's choice?
I've restarted PSPad, I've changed LOGFontName in the "Direct edit" - nothing - PSPad is restarting with default (or more right - main) "Courier New" font.
If I change the main font of the editor (Format->Font), the font of the LOG windows changes accodingly sad smiley
#4 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-28 06:08 | IP: IP Logged
Ilya:
I have to check it. There is something strange... sad smiley
#5 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Funbug | Date: 2008-05-28 07:12 | IP: IP Logged
I was too fast. When "<SSL>NONE</SSL>" appears in the export file, PSPad imports that account. But with "<SSL>AUTH TLS</SSL>" it won't.
#6 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-28 07:21 | IP: IP Logged
Yes, because PSPad doesn't support TLS authorization yet.
#7 Re: PSPad unicode 4.5.4 (2317) English
Posted by: nTE | Date: 2008-05-28 08:04 | IP: IP Logged
There is a little problem with the XHTML multihighlighter for template code (eg. Smarty):
{def $foo = 'bar' } <p>{$foo}</p>
This highlights the <p> as template code which is wrong.
The problem seems to be the closing bracket on the new line.
#8 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-28 09:21 | IP: IP Logged
nTE:
Problem found and fixed
#9 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Funbug | Date: 2008-05-28 09:51 | IP: IP Logged
Okay, but it would be nice if they were imported anyway. Without TLS.
#10 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-28 10:36 | IP: IP Logged
Funbug:
No problem, I will remove condition
