You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2317) English
Posted by: poncho | Date: 2008-06-02 06:31 | IP: IP Logged
Any news to FTP symlinks?
-> forum.pspad.com
Posted by: simbabque | Date: 2008-06-02 06:56 | IP: IP Logged
When I open a file encoded in ANSI (Windows) PSPad sort of mangles all the § Signs. We sometimes use those in Perl code as delimiter for q and qq. With this version, they all vanish and after saving they are truely gone from the document. I spent the last 15 minutes searching the svn for the bad guy who broke my code until I figured out I did it myself.
I guess it's got something to do with the unicode updates. In previous versions it used to highlight the § in a different colour than everything else, btw.
Posted by: pspad | Date: 2008-06-02 09:13 | IP: IP Logged
simbabque:When I open a file encoded in ANSI (Windows) PSPad sort of mangles all the § Signs. We sometimes use those in Perl code as delimiter for q and qq. With this version, they all vanish and after saving they are truely gone from the document. I spent the last 15 minutes searching the svn for the bad guy who broke my code until I figured out I did it myself.
Send me to support mail as mail attachment some file with '§' and write me what I want to do to simulate your problem
Posted by: pspad | Date: 2008-06-02 15:30 | IP: IP Logged
poncho:
In the next build
Posted by: Ilya | Date: 2008-06-03 12:45 | IP: IP Logged
pspad:Ilya:How can I save another font's choice?
I've restarted PSPad, I've changed LOGFontName in the "Direct edit" - nothing - PSPad is restarting with default (or more right - main) "Courier New" font.
If I change the main font of the editor (Format->Font), the font of the LOG windows changes accodinglyI have to check it. There is something strange...
The problem is solved in 2319 Thank you!
Posted by: hibou57 | Date: 2008-06-05 11:53 | IP: IP Logged
PSPad 4.5.4 2317 seems to locks on UTF-8 what ever I switch to in the format menu or weither or not I set the automatic code page detection.
It insists on opening all ISO-8859-2 files as UTF-8, and it removes all cahracters like "éèàç", and the like.
The full content of a important big file has been totaly destroyed.
Never use this build!
Edited 2 time(s). Last edit at 2008-06-05 11:59 by hibou57.
Posted by: lemmi | Date: 2008-06-09 16:35 | IP: IP Logged
Editor script option 'modified' works perfectly for me!
Thank you very much!!
Posted by: stater | Date: 2008-09-03 07:30 | IP: IP Logged
First, thanks for such a great freeware editor of Pspad.
I have met a problem like this question.
When I type a symbol as "*"(star) and press "Enter", it would append a "*" to the newline automatically.
I think it would not be safe for a editor using C/C++ language. Because symbol "*" mean a pointer in C/C++.
So, would you please give me a clue to disable the function or how to fix it.Thanks!!
Posted by: vbr | Date: 2008-09-03 09:05 | IP: IP Logged
stater:When I type a symbol as "*"(star) and press "Enter", it would append a "*" to the newline automatically.
Try
Program settings :: Direct edit: Special settings
ContinueComment=0
Posted by: stater | Date: 2008-09-04 02:18 | IP: IP Logged
ContinueComment setting is the answer for me.
