You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.4 (2309) English
Posted by: Patrik | Date: 2008-03-11 09:18 | IP: IP Logged
I sent it right now.
Patrik
Posted by: pspad | Date: 2008-03-11 09:56 | IP: IP Logged
Patrik:I sent it right now.
Patrik
Problem was found in comma symbol in the class definition:
public class GrammarCheckMain: ITagEditorPlugIn, ITeamworksVerificationPlugin
Fix will be available in the next build
Posted by: gmc4by | Date: 2008-03-18 23:11 | IP: IP Logged
One problem I have noticed with this version (4.5.4-2309) is that the indent block feature is slower, and sometimes can take up to 2 minutes, even if I'm only tring to indent 1 or 2 lines.
Also, in COBOL mode Add/Remove comment puts an asterisk in position 1, or removes it from position 1, when it needs to be in position 7. I tried to come up with a workaround, but I wasn't able to figure one out.
With syntax highlighting, why do some of the background colors only show if there is a character there? The "Tag Area" in COBOL doesn't show with the selected background color, unless there is a character in that position.
Thank you very much for this program, it's the best one I've ever used!
-Chris
Posted by: Lolo | Date: 2008-03-19 11:33 | IP: IP Logged
Hi Jan,
I have a bug with Tab.
Here is a simple way to reproduce the bug.
Create 2 files named:
fisrt one: Copie de Abcde.012345.ABCDEFGHIJ.KlmnoQrstuvWXYZABCDEF_GHIJ KL MNOPQR_123456_7890.stuvx.xyz.abcdefg.hijklmnop
second one:Copie (2) de Abcde.012345.ABCDEFGHIJ.KlmnoQrstuvWXYZABCDEF_GHIJ KL MNOPQR_123456_7890.stuvx.xyz.abcdefg.hijklmnopAbcde.012345.ABCDEFGHIJ.KlmnoQrstuvWXYZABCDEF_GHIJ KL MNOPQR_123456_7890.stuvx.xyz.abcdefg.hijklmnop
Now, open the second one (you should have the same things than FirstStep.jpeg) and after the fisrt one (see SecondSecond.jpeg)
As you can see, the tab is hidden.
I often work with long filename and this behavior a rather annoying.
I hope you could fix it in the next release.
I have attached screenshots and my PSPad.ini file : www.midload.com
I hope it will help you
Thanks in advance and have a nice day.
Posted by: pspad | Date: 2008-03-19 14:15 | IP: IP Logged
gmc4by:One problem I have noticed with this version (4.5.4-2309) is that the indent block feature is slower, and sometimes can take up to 2 minutes, even if I'm only tring to indent 1 or 2 lines.Also, in COBOL mode Add/Remove comment puts an asterisk in position 1, or removes it from position 1, when it needs to be in position 7. I tried to come up with a workaround, but I wasn't able to figure one out.
-Chris
Can you send me some sample file anf your PSPad.INI ?
Posted by: Lolo | Date: 2008-03-20 11:09 | IP: IP Logged
Hello Jan,
Did you manage to reproduce this behavior?
See above: forum.pspad.com
I forgot to mentioned that I use a screen resolution of 1280x1024 and I am on Windows 2000 sp4.
I hope it will help you.
Thanks and have a nice day.
Posted by: dxgx82 | Date: 2008-03-21 07:49 | IP: IP Logged
well last fast and good working version for me is 2301
