You are here: PSPad forum > Developer forum > PSPad unicode 4.5.4 (2301) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.4 (2301) English
Posted by: pspad | Date: 01/28/2008 23:25 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.3 (2298)
News
block select with F8 works in HEX editor too
Open selected file in default application opens file in PSPad if Ctrl is pressed
go to parent folder with BackSpace key in the FTP window
Search/Replace with regular expression - number of substitution was increased to 50
removed limitation to 1024 chars in the MEMO log window style
Corrections
open file from FTP if file contains spaces in name
Open selected file in default application function opens file in PSPad
dblclick in the LOG window
button LIST and COPY in th Search dialog doesn't handle unicode
C++ code explorer and exception related to compiler conditions
Indent block function with TAB/Shift+Tab doesn't use Indent with from program settings
XML reformat with comments
Search in files function doesn't remember used code page selection
#2 Re: PSPad unicode 4.5.4 (2301) English
Posted by: Skulstad | Date: 01/29/2008 07:59 | IP: IP Logged
Hi. The 'Tool Button Icon Set' is gone...
Regards,
Jorn Chr. Skulstad
#3 Re: PSPad unicode 4.5.4 (2301) English
Posted by: Skulstad | Date: 01/29/2008 08:23 | IP: IP Logged
Sorry, just forget it. They re-appeared after a couple of tries.
Regards,
Jorn Chr. Skulstad
Edited 2 time(s). Last edit at 01/29/2008 08:27 by Skulstad.
#4 Re: PSPad unicode 4.5.4 (2301) English
Posted by: owilsky | Date: 01/29/2008 10:07 | IP: IP Logged
This bug is still there:
I wrote a js script with this command:
addMenuItem("bla", "&Textbausteine", "ifcondition", "Shift+F11");
When I press Shift+F11 the script itself it opened, the function "ifcondition" is not executed.
Can you please fix this? This is very annoying.
Thanks for your hard work,
Oliver
Oliver Kötter
#5 Re: PSPad unicode 4.5.4 (2301) English
Posted by: pspad | Date: 01/29/2008 10:56 | IP: IP Logged
Program setings / Program
choose icon set.
I made some changes due to increase program stability -move some thigs from resource directly into program e.t.c.
I forgot include iconset into beta build. I will correct it tonight
#6 Re: PSPad unicode 4.5.4 (2301) English
Posted by: Funbug | Date: 01/29/2008 11:08 | IP: IP Logged
Yay, thanks! smiling smiley
#7 Re: PSPad unicode 4.5.4 (2301) English
Posted by: Rok | Date: 01/29/2008 14:06 | IP: IP Logged
Sorry to bother you again with openFileFromFTP, but I've found a bug again.
In version 2301 I cannot use openFileFromFTP command with full path filename (e.g. "/tmp/foo"):
Set tmpeditor = newEditor()
tmpeditor.openFileFromFTP("/tmp/foo")
It works only with filename without path (e.g. "foo"), so the only way is to use it as follows:
ftpCommand("CWD /tmp")
tmpeditor.openFileFromFTP("foo")
But in that case you get wrong path for backup file - in my case:
<backup dir>\koh\opt\OV\bin\foo
instead of:
<backup dir>\koh\tmp\foo
Can you please check it?
Thank you and best regards,
Rok
#8 Re: PSPad unicode 4.5.4 (2301) English
Posted by: sholle | Date: 01/29/2008 16:14 | IP: IP Logged
FTP works great with VMS.
Thank you!!!
#9 Re: PSPad unicode 4.5.4 (2301) English
Posted by: pypardo | Date: 01/30/2008 09:19 | IP: IP Logged
Hi all,
* dbl-click on log window fixed in b2301, it drives me directly on right error line.
Many thanks...
Best regards
pierre
Edited 1 time(s). Last edit at 01/30/2008 09:20 by pypardo.
#10 Re: PSPad unicode 4.5.4 (2301) English
Posted by: gurbao | Date: 01/30/2008 12:41 | IP: IP Logged
grinning smiley
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
