You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2282) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 4.5.3 (2282) English
Posted by: pspad | Date: 10/14/2007 17:44 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
ftp.siliconhill.cz
Changes to 4.5.3 (2281)
News
Cobol - highlighting brackets, IF, EXEC
Scripting - new function for LOG window (see Readme.rtf in .\Script folder)
Code explorer for Verilog
Corrections
background color with highlighting matching brackets and expressions after leave
Log window painting problems
#2 Re: PSPad unicode 4.5.3 (2282) English
Posted by: wal | Date: 10/15/2007 08:03 | IP: IP Logged
Hi Jan,
The problem with corrupted output window seems is solved. At least I can't repeat it anymore. And messages of external tool are shown immediately in output window as they were before build 2281. Great work!
Hope you will find some time to solve problem with C++ code explorer which started from build 2281 (forum.pspad.com), or if this requires too much efforts, maybe simpler to switch back to old C++ code explorer?
Best regards and big thanks for amazing editor!
wal
Edited 2 time(s). Last edit at 10/15/2007 08:08 by wal.
#3 Re: PSPad unicode 4.5.3 (2282) English
Posted by: pspad | Date: 10/15/2007 08:58 | IP: IP Logged
I know about this problem, but I am not able to do all in several days. I need to earn some money for my live, not only work on PSPad winking smiley
#4 Re: PSPad unicode 4.5.3 (2282) English
Posted by: wal | Date: 10/15/2007 09:40 | IP: IP Logged
Yes, I understand that you hardly worked on problem with output window and appreciate your altruistic work on PSPad. I just reminded this recent small problem because usually is simpler to solve problem while it is fresh. Certainly this can wait... smiling smiley
Thank you for the fast response!
#5 Re: PSPad unicode 4.5.3 (2282) English
Posted by: kiendlm | Date: 10/15/2007 10:04 | IP: IP Logged
Hi Jan,
thanks for the new build. It seems that there is a little problem with the C/C++ highlighter, because the setting "Use alternate preprocessor style" has no effect in this build. Could you have a look at this?
Markus
#6 Re: PSPad unicode 4.5.3 (2282) English
Posted by: tyzio | Date: 10/15/2007 14:14 | IP: IP Logged
The problem with LOG window is fixed. I'm not able to reproduce this problem.
Thanks Jan, great job!!
#7 Re: PSPad unicode 4.5.3 (2282) English
Posted by: mahira | Date: 10/15/2007 15:10 | IP: IP Logged
Good point grinning smiley
Btw, thanks for the new fix...
...I need to earn some money for my live, not only work on PSPad winking smiley
#8 Re: PSPad unicode 4.5.3 (2282) English
Posted by: raeubi | Date: 10/16/2007 08:17 | IP: IP Logged
... I need to earn some money for my live...
Welcome to the club winking smiley
and thanks for the new build smiling smiley
#9 Re: PSPad unicode 4.5.3 (2282) English
Posted by: broker70 | Date: 10/16/2007 17:27 | IP: IP Logged
Hello Jan,
thanks a lot for that fix of the LOG window. Also at my colleagues this fix seems to be working. I know, that it's a hard job once your great editor is used by so many people and (beta) testers...
Thanks!
#10 Re: PSPad unicode 4.5.3 (2282) English
Posted by: SteveLeBlanc | Date: 10/17/2007 08:00 | IP: IP Logged
BUG: Broken Script compiler. Scripts that used to work in the last stable version 2241, do not work in Beta 4.5.3 2282. Seems to be a problem with the assignLog() function.
Error: Object doesn't support this property or method. My CODE: var edlog = newEditor(); edlog.assignLog(); (Running PSPad 4.5.3 2282 on Win98)
I did read about the new functions for LOG window (in Readme.rtf in .\Script folder) No mention of the assignLog() function.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
