You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2271) English
Posted by: pspad | Date: 2007-08-08 17:31 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
ftp.siliconhill.cz
Changes to 4.5.3 (2269)
News
Code Explorer - new file types for ADA and Progress
Code Explorer - improved GameMaker parser
CSS reformat now supports CHROME
Corrections
Code Explorer - correction for PL/SQL
internal HTML preview behavior
Edited 2 time(s). Last edit at 2007-08-17 13:19 by pspad.
Posted by: holger | Date: 2007-08-08 18:45 | IP: IP Logged
Thank you for the special Code-Explorer, works fine.
Posted by: MrSpock | Date: 2007-08-08 19:01 | IP: IP Logged
Again, thanks a bunch man, especially for the updated GameMonkey code explorer! It's a huge time saver.
Posted by: mce | Date: 2007-08-08 19:45 | IP: IP Logged
The rule for the Include for Progress Code Explorer doesn't seem to be working for include files with parameters.
For example {myinclude.i} will show in the explorer, but {myinclude.i "abc"} will not.
Thanks,
Cristian
Posted by: komfa | Date: 2007-08-09 05:19 | IP: IP Logged
Hello Jan, wow.
I'm very happy. It works perfect for me and ftProgress is 10times faster then ftSQL-Syntax.
Many Thanks
Christian
Posted by: pspad | Date: 2007-08-09 06:40 | IP: IP Logged
mce:The rule for the Include for Progress Code Explorer doesn't seem to be working for include files with parameters.
For example {myinclude.i} will show in the explorer, but {myinclude.i "abc"} will not.Thanks,
Cristian
OK. I will modify it. Thi is a problem, I don't know syntax of any labnguages and I havn't time to study it.
I am dependent of you informations. As exact information I get...
Posted by: holger | Date: 2007-08-09 07:46 | IP: IP Logged
Cristian
I can add that a Includefile with \ or / or without extension is also not shown in Code-Explorer.
Wow, Temp-Table definition are there now.
Questions:
Would it be possible to make the same for Variables, Parameters, Streams, Workfiles, Buffers, Browsers, Frames, Queries and Preprocessordefinitions (like
&GLOBAL-DEFINE Autor Holger)?
Could these things be shown in own Sections under the Function or Procedure they're defined (or maintree for globally in the File)?
again many Thanks for the new Code-Parser.
Holger
Posted by: holger | Date: 2007-08-09 07:51 | IP: IP Logged
pspad:I am dependent of you informations. As exact information I get...
I can send you the helpfile for Progress 10.1 A (Openedge), if you want.
Oh, and don't forget Includedefinitions can be multilined
Holger
Posted by: pspad | Date: 2007-08-09 07:59 | IP: IP Logged
holger:pspad:I am dependent of you informations. As exact information I get...I can send you the helpfile for Progress 10.1 A (Openedge), if you want.
Oh, and don't forget Includedefinitions can be multilinedHolger
As I wrote, I have no time to study help files. Even when I read it, I am not able to get all possibilities without deep study of the syntax.
Quickest way is write me what you want
Posted by: pspad | Date: 2007-08-09 08:04 | IP: IP Logged
holger:I can add that a Includefile with \ or / or without extension is also not shown in Code-Explorer.Wow, Temp-Table definition are there now.
Questions:
Could these things be shown in own Sections under the Function or Procedure they're defined (or maintree for globally in the File)?again many Thanks for the new Code-Parser.
Holger
I can add anything if you give me detail description.
But I suggest you to add only necessary things, because each new things slow up parsing.
I see, here is a several progress developers. You can discute on final Progress Code Explorer look (Start new topic), hat should be as the Code explorer content, what order of the items, if some tree hould be expanded as defaults or not...
When you will have results, send me it with some code example with all alternatives.
