You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2261) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-11 12:46 | IP: IP Logged
Download links:
pspad.cincura.net (1.7 MB)
pspad.siliconhill.cz (1.7 MB)
Changes to 4.5.3 (2259)
News
Unicode file name handling works was started. In this moment is possible to open files with unicode names. To display file name correct in the form title or file tab is necessary to set some unicode font in PSPad localization
In Code clips is possible to change default chars for cursor position and selected text placement. Is necessary to include new section into clip file:
[Clip Settings]
CursorChar=|
SelectionChar=§
Send me back modified clip files please.
New localization - Lithuanian (Darius Gudavičius)
Corrections
Open R/O copy for HEX editor
Wrap text problem
User convertors - Morse to Text
Interactive clips - quotas around description
Current line highlighting in new files
Search current word/selection with Ctrl+Alt+Up/Down if previously Regular expression was used
FTP connection window wasn't resizable
Python Code explorer - import
#2 Re: PSPad unicode 4.5.3 (2261) English
Posted by: MrSpock | Date: 2007-03-11 16:23 | IP: IP Logged
Corrections
Thanks for the new build. I can't find a new CharToMorse.ini. Am I blind, or did you forget to put it into the cab?
#3 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-11 16:36 | IP: IP Logged
There was a problem in program code, not in the definition
#4 Re: PSPad unicode 4.5.3 (2261) English
Posted by: MrSpock | Date: 2007-03-11 16:56 | IP: IP Logged
Ah, I see. Thank you.
#5 Re: PSPad unicode 4.5.3 (2261) English
Posted by: divopsp | Date: 2007-03-12 12:06 | IP: IP Logged
Little bug.
Find function: regardless if add line numbers is checked or not, List command adds anyway line numbers.
Verified with this release (2261) and previous versions
Bye
Ivo
#6 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-12 12:30 | IP: IP Logged
divopsp:
Little bug.
Bye
Ivo
This works for COPY button, not for list button
#7 Re: PSPad unicode 4.5.3 (2261) English
Posted by: owilsky | Date: 2007-03-12 13:56 | IP: IP Logged
Hi Jan,
I tried the new function getVarValue() that was introduced in 2259.
I used this code:
var temp = getVarValue("%UserName%");
echo(temp);
However it seems not to work always. I did not test all variables, so here are only some:
These work fine:
%Time%
%Date%
%FileName%
%FilePath%
These don't work:
%UserName%
%ComputerName%
And worst for me: All User variables don't work.
Oliver Kötter
#8 Re: PSPad unicode 4.5.3 (2261) English
Posted by: owilsky | Date: 2007-03-12 13:57 | IP: IP Logged
Also, can you elaborate what the second (optional) argument "filename" of the function getVarValue(variable[, filename] :string) does?
Thanks,
Oliver
Oliver Kötter
#9 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-12 15:02 | IP: IP Logged
owilsky:
Hi Jan,
I used this code:
echo(temp);
These work fine:
%Time%
%Date%
%FileName%
%FilePath%
These don't work:
%UserName%
%ComputerName%
Go to menu Settings / USer variables, open dialog and confirm it.
#10 Re: PSPad unicode 4.5.3 (2261) English
Posted by: owilsky | Date: 2007-03-12 15:15 | IP: IP Logged
Yes, I know that dialog. I entered some user variables:
%Tools_Dir%
%NIPO_Developer%
%NIPO_Client%
%test%
I confirmed that the Variable.INI contains the right values.
Oliver Kötter
