You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2199) English
Posted by: vserghi | Date: 2006-04-01 09:37 | IP: IP Logged
I can agree with this. Tested on WinXP2, SP2
Vas.
Posted by: MrSpock | Date: 2006-04-01 15:29 | IP: IP Logged
>In any case, if I set the Code Explorer window to not be displayed,
>the Splash Screen remains visible the whole time.
I can't confirm that. I have the code explorer turned off by default, and still the splash screen goes blank for approximately half a second before the program is loaded. But I don't mind much.
Posted by: MrSpock | Date: 2006-04-01 17:23 | IP: IP Logged
Hi @ll,
Heiner Meiners wrote:
> 1. I did a Find/Replace in Files (searching a string that occurs
> enough times to fill the search result list so there is a scrollbar
> shown to the right). 3. Move the cursor to the left of the Search in
> Files Results window (where the buttons for expand/collapse/open all
> are. - The help text for the buttons is shown where otherwise the
> Code Page is displayed in the status line below. 4. When the cursor
> is moved back to any position that leads to redisplay the Code page
> in the status line, the 4 small rectangles in the status bar between
> cursor position information and character information are filled with
> blue background and strange content.
I've been observing the same thing for quite a while now, and it also happened with builds prior
to 2199. On my machine it looks like this:
The one thing I would like to add is that while the "find in files" method is quite likely to produce this behavior,
(a) it is by no means the only case in which it occurs, and
(b) it does *not* happen always when I do as Heiner described.
For me, the background of the small rectangles has always been white so far, and the "strange content" always looks like parts of the "Ximian" toolbar that I use.
Nachricht bearbeitet (01.04.2006 19:29)
Posted by: pspad | Date: 2006-04-01 17:23 | IP: IP Logged
OK. I hope I solved this problem.
Posted by: Anonymous User | Date: 2006-04-01 18:53 | IP: IP Logged
So any thoughts or comments on the word wrap option being randomly disabled with all files and always being disabled with read-only files issue?
Thanks and keep up the good work.
Posted by: Replika | Date: 2006-04-02 15:07 | IP: IP Logged
With Highlighter, the comment's line-height is smaller than of normal. So it not show underscore characters "_".
ex.
// P_S_PAD => // P S PAD
Posted by: pspad | Date: 2006-04-02 15:27 | IP: IP Logged
Program settings / Direct edit
change value of the ExtraLineSpacing variable
Posted by: ricky | Date: 2006-04-03 10:26 | IP: IP Logged
Great,
but ... perhaps i'm stupid, but i don't find " F1InEditor in the [Special Settings] section "
where do I have to go to find it ?
Sorry to be so stupid and annoying, but at my age, it's difficult to hope any change ...
thanks for your ( as usual) quick response.
Posted by: pspad | Date: 2006-04-03 10:38 | IP: IP Logged
1. save program settings
2. go to program settings / Direct edit and scroll right window several lines down
Posted by: ricky | Date: 2006-04-03 11:42 | IP: IP Logged
as usual , many thanks. Works fine with all i wanted
Regards
