You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2134) beta English
#31 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: Pim | Date: 2005-10-13 11:02 | IP: IP Logged
I sometimes experience similar problems like Dwornik that some shortcuts don't work anymore. Changing the syntax highlight and then choosing your current syntax highlight sometimes works
Pim
#32 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: Dwornik | Date: 2005-10-13 11:11 | IP: IP Logged
Good idea Pim. I'll try this solution, thanks!
#33 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: Pim | Date: 2005-10-13 12:09 | IP: IP Logged
I found the following when having an open project
choose ctrl-D on an open file
save the file in the project directory
choose Yes on dialog "Add file to project"
choose close all from the file menu
choose No on dialog "Close project File?"
The file is now deleted from my harddrive
#34 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: pspad | Date: 2005-10-13 12:16 | IP: IP Logged
Already reported. Wait for next build.
#35 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: henry | Date: 2005-10-14 10:29 | IP: IP Logged
In PHP Code Explorer list Javascript function issue.
I have a PHP script uses the class mm_nav. The function MM_findObj and MM_* functions are actually Javascript place inside a single quote declaration. But in the Code Explorer MM_findOBj will appear.
I have attached PHP code, for your testing. Fix it when you have the time.
class mm_nav {
//dreamweaver navigation implementation
var $preloadArray;
var $js_patch; //standard function to be patch on pg so that nav will work
function mm_nav() {
//Constructor
$preloadArray = Array(); // init as Array
$js_patch = '
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
}//method mm_nav
function mm_add_preload($img) {
$preloadArray[] = $img;
}// method mm_add_preload
function mm_nav($img) {
$nav = '<a href="#" onMouseOut="MM_swapImgRestore()" ';
$nav .= 'onMouseOver="MM_swapImage(';
$nav .= ',1);">';
$image
'skin_r3_c3','','images/skin_r3_c3_f2.jpg' <img name="skin_r3_c3" src="images/skin_r3_c3.jpg" width="122" height="31" border="0" alt=""></a>
#36 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: DJ N-4ceR | Date: 2005-10-14 13:40 | IP: IP Logged
Would like to have added the command PASV for FTP keep alive.
#37 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: Chris Pirillo | Date: 2005-10-14 17:37 | IP: IP Logged
Hrm... for some reason, today, no matter what I do... I can't seem to get text to select properly. I highlight a certain section in the file (HTML, text, etc.) and it seems to either (a) not select what's seen, or (b) cause the text to jump around. Major, major, major usability bug.
#38 cons
Posted by: shidf | Date: 2005-10-14 17:42 | IP: IP Logged
Generally this PsPad is getting better and better. But here is my concern:
1) it's bigger and bigger on the disk. Can I selectively delete something? any guide?
2) Occupies mor and more memory, typically 40M in my usage. Can I have chance to configure it to use less memory?
3) it's slower and slower, especially open a larger file, say 10Mb.
I prefer the old light small less functional versions.
#39 Re: PSPad UNICODE 4.5.0 (2134) beta English
Posted by: Jume | Date: 2005-10-15 06:11 | IP: IP Logged
there seems to be some problems with the redraw of the cursor leaving "ghost images", typically right after tab chars but also in other places, i suposse the problem is the base component but anyways i post it, ill upload a image when i can
[edited]
here it is :
www.konithuki.com
weirdly, i found that it only happens with selected fonts so maybe its my font's fault anyways, until someone can confirm the same problem it may be not worth to look to its solution
Post Edited (10-15-2005 08:26)
#40 Re: cons
Posted by: pspad | Date: 2005-10-15 08:43 | IP: IP Logged
What you mean ?
PSPad.EXE size is up to 4MB
Instalation of last full version takes about 8MB on the HDD
You havn't to install all things from package or use the CAB archive end extract what you want only
If you run empty PSPad, it occupies about 10MB. If you open file (depend of file size) it takes another 1 MB.
PSPad works internally in UNICODE. It mean each char takes 2 bytes in memory. If you open 10MB file, PSPad need 20 MB memory to store it.
If you use SpellCheck, PSPad must load dictionary content into memory. With English spell dictionary it takes another 10 MB
You mean its too big ?
> 3) it's slower and slower, especially open a larger file, say > 10Mb.
I don't prevent you to use the old version...
