You are here: PSPad forum > Bug report / Hlášení chyb > Re: File won't save bug?
#1 File won't save bug?
Posted by: clam | Date: 2013-11-08 12:59 | IP: IP Logged
This has recently started occuring with PS pad. Might be from a newer update. At random times. I can't save. I have to resave the file under a different name. No changes in settings like read only etc...
It will say "error saving file...(pathway here...)"
Running Windows 7
PS pad 4.5.7 (2450)
#2 Re: File won't save bug?
Posted by: pspad | Date: 2013-11-08 13:31 | IP: IP Logged
It happened in case you try to save file into location where are no write rights or file you want to rewrite is locked by another application.
Can I ask where is file placed? Maybe you use some synchronized folder (Google drive, DropBox, ...) and you try to save file in the moment it's synchronized to web.
Edited 1 time(s). Last edit at 2013-11-08 13:33 by pspad.
#3 Re: File won't save bug?
Posted by: Howzit | Date: 2014-01-13 12:13 | IP: IP Logged
I have the same problem.
Write permission is correct, keep alive is all fine,
it happens random where I also get a file save error...
clam:
Running Windows 7
PS pad 4.5.7 (2450)
#4 Re: File won't save bug?
Posted by: pspad | Date: 2014-01-13 13:53 | IP: IP Logged
Keep alive? Do you have problem to save file into your FTP?
Can't be a problem you save file into some shared service folder? E.g. DropBox, Google drive, ...?
