You are here: PSPad forum > Bug report / Hlášení chyb > PHP - String and PHP
Posted by: Zebra Sin | Date: 2013-12-22 12:24 | IP: IP Logged
Hello, I founded a bug in PSPad and his syntaxic coloration for PHP String.
I can't write a php end tag in a php string. The problem is gone with a new php file Inside pspad editor, but it still here when I open a php file or a project from Windows Explorer.
Example:
echo '<?php tests ?>';
I must code this in this to avoid the problem.
echo '<?php tests ?' . '>';
Well, this is problematic, I must use a concat operator, and a problem to reread my code.
PS: My apologizes for my bad English, I'm french.
Edited 1 time(s). Last edit at 2013-12-22 12:25 by Zebra Sin.
Posted by: carbonize | Date: 2013-12-24 10:37 | IP: IP Logged
This has been mentioned repeatedly. It is an issue when usingHTML Multihighlighter only. Switch highlighter to PHP.
Carbonize
Posted by: Zebra Sin | Date: 2013-12-25 08:49 | IP: IP Logged
Thanks you, but how can I do that please ?
Posted by: pspad | Date: 2013-12-25 09:20 | IP: IP Logged
Menu View / Change syntax
or toolbar button
or click on the syntax name in Statusbar
If you don't want to open PHP files in HTML multihighlighter, go to program settings / Multihighlighter and uncheck <? ?>
Posted by: Zebra Sin | Date: 2013-12-26 08:26 | IP: IP Logged
Thanks you, it works correctly now
