You are here: PSPad forum > English discussion forum > Re: German Umlauts ...?
Posted by: hlk123 | Date: 2017-12-28 11:00 | IP: IP Logged
Thank you
I wish you a Happy New Year 2018.
Now I'll drive to Lago di Garda and Venice ...
@Steffen
I've downloaded it. Thks.
Posted by: aGerman | Date: 2017-12-28 11:49 | IP: IP Logged
Have fun in Italy All the best for 2018!
Steffen
Posted by: Andreas | Date: 2017-12-28 20:35 | IP: IP Logged
pspad:I suggest you to use UTF-16LE. UTF-8 with BOM (Begin Order Mark) is useable too, but UTF-16 is better standard.
Sorry Jan but I have to contradict. Most used format is UTF-8 without BOM (Byte Order Mark) en.wikipedia.org.
You can use UTF-8 with your programming language, in internet, in programs and databases with almost any language. I only use UTF-8 everywhere for about 8 years without trouble in any program.
Using a BOM can lead to conflicts with a programming language. E.g. in PHP. You then have to detect your files with BOMs, which is not easy to do, and remove the BOM from those files.
Posted by: pspad | Date: 2017-12-28 21:08 | IP: IP Logged
UTF-8 without BOM is used mostly for PHP programming, cause Apache doesn't accept BOM.
If you want to use UTF-8 for general text, it's better to add BOM. It will prevent wrong file opening. This is the BOM purpose.
Posted by: aGerman | Date: 2017-12-29 02:36 | IP: IP Logged
That's what I suggest along with my tool:
Quote:Some rules of thumb when to add or omit BOMs:
- Add the BOM to text files that are intended to be read in text editors on Windows.
- Omit the BOM in markup text (such as HTML or XML) where the encoding is specified in the markup or where it defaults to be recognized as UTF-8.
- Omit the BOM for files that are intended to be shared with other operating systems like Unix or Linux.
- Never use a BOM for text that you append to an existing file.
Steffen
