You are here: PSPad forum > English discussion forum > Search: small bug
Posted by: massimobalestra | Date: 2017-03-30 15:32 | IP: IP Logged
I found a small bug in version 5.0.0 (163).
I don't know if it is a problem only of the translations or a more general problem. I tried with the English localization and the Italian: it behaves in the same way.
1) I open a file.
2) Then Search-->find (I have a shortcut with Ctrl+F for this)
3) I write a string in the search field i.e. john.
4) I press enter. It finds the first occurrence of john.
5) I press F3 (Find Next) several times until it reaches the last occurrence in the document.
6) I press F3 again.
7) An alert popup appears saying: Next occurrence of "" not found. Continue search ...
The problem is that between the quote it is empty and it should contain the string I wrote at point 3 (john) or at least part of it.
The same empty string in the popup appears if at point 3 I write something that cannot be found.
It is very useful to have in that popup alert the string I was looking for in the case I rerun the same search (just pressing F3) later or in a different file: it tells me if I a running the right search.
Thank you for the great program you wrote and you are maintaining.
(I can't wait to see it with the new Engine)
Massimo
Posted by: Stefan | Date: 2017-03-30 17:00 | IP: IP Logged
Seems to be a problem on parsing the languages files
and replacing the "%s" placeholder with current content.
I have seen the same and reported there
forum.pspad.com
I am sure Jan will fix that soon.
Posted by: pspad | Date: 2017-03-30 17:49 | IP: IP Logged
Stefan:Seems to be a problem on parsing the languages files
and replacing the "%s" placeholder with current content.I have seen the same and reported there
forum.pspad.comI am sure Jan will fix that soon.
I found it yesterday and fixed it already. In the next build it will be OK.
I replaced mechanism to be save and independent of substitutions number. It could cause exceptions.
Posted by: massimobalestra | Date: 2017-03-30 18:02 | IP: IP Logged
Thank you.
Posted by: pspad | Date: 2017-03-30 18:16 | IP: IP Logged
massimobalestra:7) An alert popup appears saying: Next occurrence of "" not found. Continue search ...
I found this problem yesterday and fixed it.
