You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (156) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-28 19:50 | IP: IP Logged
mali_zeeko:
PsPad 5.0.156 crashes while opening C++ source code:
Is it regular crash with this source? It can be joined to code explorer or C++ highlighter. If it happened always with this source, can you send this file to support mail for analysis? I will keep it private and delete after testing.
#12 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-29 06:28 | IP: IP Logged
sandrosilveira:
COBOL Syntax highlighting Problems (colorization of 'Reserved Words'):
You are right, there was bug in my code. Fix will be available in next build.
#13 Re: PSPad unicode 5.0.0 (156) English
Posted by: pspad | Date: 2017-03-29 06:34 | IP: IP Logged
mali_zeeko:
Thank you for the new C++ keywords. I noticed that alternatives for logical and bitwise operators are not recognized: and, bitor, or, xor, compl, bitand, and_eq, or_eq, xor_eq, not, not_eq
I will add it too
#14 Re: PSPad unicode 5.0.0 (156) English
Posted by: Stefan | Date: 2017-03-29 08:07 | IP: IP Logged
Update on my post:
Stefan:
Deutsch.ini is on its way by separate eMail.
- Typo:
JSON pretty print reformar
JSON pretty print reformat
- Need help:
where can I find that string in the GUI?
JSON pretty print reformar[/code]
I have now translated to
aJsonReformat_Caption=JSON-Code formatieren
"Format > JSON-Code formatieren"
Just like "HTML > HTML-Code formatieren"
and "HTML > CSS-Code formatieren"
BTW: I can't find string to translate for:
"HTML > PHP Code beautifier "
Edited 2 time(s). Last edit at 2017-03-29 08:08 by Stefan.
#15 Re: PSPad unicode 5.0.0 (156) English
Posted by: sandrosilveira | Date: 2017-03-29 16:33 | IP: IP Logged
sandrosilveira:
Jan,
I updated to 5.0.0 (161) and is working fine now!
Thank you!
#16 Re: PSPad unicode 5.0.0 (156) English
Posted by: human | Date: 2017-03-30 11:31 | IP: IP Logged
Stefan:
Thank you Stefan for the translation, just tested 5.0.0 (163) and on file reload [CTRL]+[R] it says:
5.0.0 (163), German:
"" %sA C H T U N G ! Ihre momentanen Änderungen verwerfen und die Datei in der letzten Version öffnen?
#17 Re: PSPad unicode 5.0.0 (156) English
Posted by: Stefan | Date: 2017-03-30 13:17 | IP: IP Logged
human:
...just tested 5.0.0 (163) and on file reload [CTRL]+[R] it says:...
Thank you very much!
Changed on my local file:
rs_ReopenWarn="%s" %sA C H T U N G ! Ihre momentanen Änderungen verwerfen und die Datei in der letzten Version öffnen?
rs_ReopenWarn="%s" \nA C H T U N G ! Ihre momentanen Änderungen verwerfen und die Datei in der letzten Version öffnen?
#18 Re: PSPad unicode 5.0.0 (156) English
Posted by: Stefan | Date: 2017-03-30 13:40 | IP: IP Logged
Tested with 163
rs_ReopenWarn=File "%s" was changed. After reopen, changes will be lost. Continue?
will NOT show the file name:
Warning
File "" was changed. After reopen, changes will be lost. Continue?
OK Cancel
